[mapserver-users] GetFeatureInfo from a JavaScript client [SOLVED]
David Alda Fernandez de Lezea dalda at ikt.es
Thu Jun 10 06:51:40 EDT 2010
Hi Jukka,
Definetaly you're a Master!! That pointed me the right way. The asp web proxy was truncating the url passed as parameter to him, so I made some changes and it worked.
Thanks man, what a relief...
Regards,
Un saludo,
David Alda Fernández de Lezea
Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
IKT
Granja Modelo s/n · 01192 · Arkaute (Araba)
Tlfnos.: 945-00-32-95                         Fax: 945-00.32.90
email: dalda at ikt.es                                web: www.ikt.es
-----Mensaje original-----
De: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
Enviado el: jueves, 10 de junio de 2010 12:15
Para: David Alda Fernandez de Lezea; mapserver-users at lists.osgeo.org
Asunto: Re: [mapserver-users] GetFeatureInfo from a JavaScript client
Mapserver does probably not receive a valid GetFeatureInfo request. Open the Apache access log file and see what is coming in. You can also test the request from browser.
-Jukka Rahkonen-
David Alda Fernandez de Lezea wrote:
> Hi folks,
> My situation: We've developed a GIS web viewer based on OpenLayers, with some particular configurations, and is located in a server, let's called "Server A", and we also have some other web applications that include this viewer to show some information and they're located in "Server B". The thing is that to avoid the cross-domain problem we've created an ASP script located in "Server B" that calls mapserver to receive the getfeatureinfo request, but when I try it in my web browser I get the following message:
> mapserv(): Web application error. Traditional BROWSE mode requires a TEMPLATE in the WEB section, but none was provided.
MapFile:
MAP
	NAME "WMSSERVER"
		STATUS ON
		EXTENT 460000 4690000 610000 4820000 # Euskadi
		SHAPEPATH "shapes_estaticos/"
		FONTSET "misc/fonts/fonts.txt"
		UNITS METERS
		DEBUG ON
		CONFIG "MS_ERRORFILE" "C:/ms4w/Apache/htdocs/MFD/tmp/ms_wms.log"
		DEBUG 5
		OUTPUTFORMAT
		   NAME gif
		   DRIVER "GD/GIF"
		   MIMETYPE "image/gif"
		   IMAGEMODE PC256
		   EXTENSION "gif"
		END
	WEB
		IMAGEPATH "C:/ms4w/Apache/htdocs/MFD/tmp/"
		IMAGEURL "tmp/"
		METADATA
			"wms_name"            	"IKT WMS Server"
			"wms_server_version"  "1.1.1"
			"wms_title"           	"Servidor WMS IKT"
			"wms_onlineresource"  	"http://192.168.1.65/cgi-bin/mapserv.exe?map=../htdocs/MFD/ejemplo_wms.map&"
			"wms_srs"       		"EPSG:23030 EPSG:4326"
			"wms_transparent"       "true"
			"wms_abstract"			"Servicio de mapas WMS de IKT Nekazal Teknologia. Powered by Apache and UMN MapServer"
			"wms_keywordlist"		"IKT,Euskadi,Mapas Euskadi"
			"wms_feature_info_mime_type"   "application/vnd.ogc.gml"
			"labelcache_map_edge_buffer" "-10"
		END
	END
	PROJECTION
		"init=epsg:23030"
	END
	LAYER
		STATUS ON
		CONNECTIONTYPE oraclespatial
		CONNECTION "admcarto/admcarto at ORA10GEX"
		NAME "RecintosSigpac"
		PROJECTION
			"init=epsg:23030"
		END
		DUMP TRUE
		TYPE POLYGON
		METADATA
			"wms_title"		    "Recintos Sigpac 2009"
			"wms_srs"             "EPSG:23030"
			"wms_name"            "RecintosSigpac"
			"wms_format"          "image/gif"
		END
		MAXSCALE 25000
		DATA "GEOMETRY FROM (SELECT * FROM GT_SIGPAC_REC_2010_ED50) USING UNIQUE gid SRID 82337" #todo el sigpac
		CLASS
			NAME "Recintos"
			STYLE
				OUTLINECOLOR 0 234 0
			END
			TEMPLATE "ms_template.html"
		END
	END
END
I've got "ms_template.html" created with the magic string.
What I'm doing wrong??
Thanks.
Un saludo,
IKT
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
