[mapserver-users] ka-Map - Mapserver - Map display problem.
Stephen Woodbridge woodbri at swoodbridge.com
Sun Jun 27 13:03:54 EDT 2010
It would help to know what version of mapserver you are now running and
what you were running before?
You should also try something like:
shp2img -m /path/to/your/mapfile.map -o junk.png
and see if it reports any errors.
Recent versions of mapserver have had a change for security purposes
which now require most mapserver support files to have well know tags as
the first line(s) of the support file.
-Steve W
Jaisen wrote:
> Hi,
> I have ka-Map implementations in my Debian (Lenny) system, and were
> working pretty well. But after a system upgrade including mapserver,
> nothing is displayed in map window. The Coords are shown as: x: NaN y:
> NaN
> And inside the folders (for example):
> var/www/mykamap/htdocs/kacache/gmap/2500/Roads/def/t0/l0/meta
> a blank text file is seen, named:
> lock_-40_-40
> and inside the folder:
> /var/www/mykamap/htdocs/kacache/gmap/2500/Roads/def/t-1640448/l9770496/meta
> another blank file is seen named:
> lock_-1640488_9770456
> What exactly is this problem? Can anybody help me to resolve it?
> When I encountered this issue previously, I reinstalled the entire
> system to resolve. Now I want to know some other way to resolve
> this problem.
> Thanks in advance.
