[mapserver-users] DXF layer definition in mapfile
Dejan Gambin
dejan.gambin at coin.hr
Fri Mar 5 02:55:42 EST 2010
Frank,
You were right (as usual I would say :-)
I was using MapServer 5.6.0 (on Mac OSX, from KyngChaos) with GDAL Complete 1.6. I upgraded GDAL to 1.7 but didn't upgrade MapServer to 5.6.1 so it was using GDAL 1.6 I suppose. Now everything works
Thanks very much
regards, dejan
On 4. ožu. 2010., at 17:06, Frank Warmerdam wrote:
Dejan Gambin wrote:
> Hi,
> Since DXF driver has been made, I would like to show a DXF file on the map. Is this possible? What syntax do I have to use to make it work?
> I have tried defining it similar to dgn syntax, but it doesn't work. I get: "msOGRFileOpen(): Open failed for OGR connection in layer `layer_name'. File not found or unsupported format.". ogrinfo works fine on this file. For example:
> My layer definition looks like this:
> LAYER # dxf
> NAME "layer_name"
> GROUP "group_name"
> STATUS ON
> TYPE LINE
> METADATA "DESCRIPTION" "Description"
> END
> CONNECTIONTYPE OGR
> CONNECTION "/Library/WebServer/Documents/demodata/test.dxf"
> DATA "0"
> STYLEITEM "AUTO"
> CLASS
> NAME "All"
> END
> PROJECTION
> "init=epsg:31275"
> END
> END
Dejan,
I suspect you have more than one gdal/ogr on your system and MapServer
isn't using the new one. Because DXF files are represented as having only
one layer you don't normally need a DATA statement to select the layer.
One example of mine looks like:
MAP
STATUS ON
EXTENT 0 80 120 160
SIZE 600 400
FONTSET "/home/warmerda/mapserver/fonts.lst"
IMAGECOLOR 0 0 128
IMAGETYPE png
LAYER
NAME shppoly
TYPE line
CONNECTIONTYPE OGR
CONNECTION "assorted.dxf"
STATUS default
STYLEITEM "AUTO"
CLASS
NAME "work"
END
END
LAYER
NAME textstuff
TYPE annotation
CONNECTIONTYPE OGR
STATUS default
STYLEITEM "AUTO"
CLASS
NAME "work"
END
END
END
and watch the world go round - Rush | Geospatial Programmer for Rent
