[mapserver-users] Average/Bilinear Resampling and Alpha Bands
Frank Warmerdam
warmerdam at pobox.com
Mon Mar 15 12:20:25 EDT 2010
Jason Beverage wrote:
> Hi all,
> I have some imagery that is in UTM that contains an alpha band that
> masks out areas with no data. When I use MapServer to reproject it to
> epsg:4326, the masked out area looks good if I set RESAMPLE=NEAREST on
> the layer. If I change the RESAMPLE option to BILINEAR or AVERAGE I
> get black splotches in the area that is transparent.
> Has anyone else seen this behavior?
Jason,
I haven't run into this before, but it sounds like a bug in the resampler.
If you can file a detailed ticket on this so that I can easily reproduce
the problem I should be able to fix it.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
