[mapserver-users] WMS GetFeatureInfo on a WFS layer
Yves Jacolin yves.jacolin at camptocamp.com
Thu Mar 25 10:26:20 EDT 2010
Hello,
Indeed, I built the last stable release of MapServer, good point ;)
We will test with another release or waiting for the next one.
Thanks for your tips !
Regards,
Y.
2010/3/25 Yewondwossen Assefa <yassefa at dmsolutions.ca>
> Hi Yves,
> Couple of things:
>  First of all, you you should be able to do a GetFeatureInfo request on
> this WFS layer. There is a bug with latest versions of MapServer I believe
> trink and possibly 5.6 (I only test trunk). The bug is described at
> http://trac.osgeo.org/mapserver/ticket/3403, and It should now be fixed in
> svn. If you are builiding aginst trunk, please give it a try.
> Other notes on
>  - I usually have a  "ows_latlonboundingbox" set on the wfs layer
>  - I usually add &RADIUS=2 when doing a GetFeatureInfo request.
> hope it helps.
> best regards,
> Yves Jacolin wrote:
>> Hi Arnd,
>> Thanks for your answer We will try an other way.
>> The 2nd given url is really a WFS server, I successfully send a GetFeature
>> request with filter parameter. :)
>> Thanks again,
>> Y.
>> 2010/3/24 Arnd Wippermann <arnd.wippermann at web.de <mailto:
>> arnd.wippermann at web.de>>
>>    Hi,
>>         as I know, you cann't request a WMS or WFS through a connection in
>>    your mapfile (results to "Search return no result"). Only with own
>>    data added as shapefile and so on, you can get a result for
>>    GetfeatureInfo requests. Wether mapinfo via ogr cann't request, i
>>    have no clue. But I would think, it should be possible.
>>         I have checked, that the url is a valid wfs server, also it seems,
>>    that it points to a wms server.
>>         Arnd
>>    *Von:* mapserver-users-bounces at lists.osgeo.org
>>    <mailto:mapserver-users-bounces at lists.osgeo.org>
>>    [mailto:mapserver-users-bounces at lists.osgeo.org
>>    <mailto:mapserver-users-bounces at lists.osgeo.org>] *Im Auftrag von
>>    *Yves Jacolin
>>    *Gesendet:* Mittwoch, 24. März 2010 10:24
>>    *An:* mapserver-users
>>    *Betreff:* [mapserver-users] WMS GetFeatureInfo on a WFS layer
>>    Hi,
>>    I added a WFS layer in my mapfile and I am using MapServer as a
>>    WMS server. I would like to send a GetFeatureInfo request on this
>>    WFS layer but I always get a "Search return no result" as answer.
>>    Is it possible to request such layer? I get same problem with an
>>    OGR connection (mapInfo file). Does the problem could occur only
>>    with a polyline feature if we click always too far of the feature?
>>    Or the problem occur from the WFS service?
>>    The WFS service I want to request in my WMS service is
>> http://carto.ecologie.gouv.fr/MEDD/wms.php?service_idx=17W&map=sacarte.map
>>    Thanks in advance for your help,
>>    Y.
>>    --     Yves Jacolin
>>    Responsable Formation et Support
>>    Camptocamp France SAS
>>    Savoie Technolac, BP 352
>>    73377 Le Bourget du Lac Cedex
>>    Tel : + 33 (0)4 79 26 57 97
>>    http://www.camptocamp.com
>>    yves.jacolin at camptocamp.com <mailto:yves.jacolin at camptocamp.com>
>> Yves Jacolin
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Assefa Yewondwossen           Software Analyst
> Email: yassefa at dmsolutions.ca    http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
Yves Jacolin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100325/b3c5c0db/attachment.html
