[mapserver-users] set COLOR to transparent?
Wendell Turner wendell at enflight.com
Mon May 3 09:53:20 EDT 2010
On Sun, May 02, 2010 at 10:05:39AM -0700, Roger André wrote:
> Hi Wendell,
> The technique I have found that works well for setting a range of values to
> be transparent is to use ImageMagick's "-transparent" command in conjunction
> with "-fuzz".  Here is an example of that:
The ImageMagick solution does just what I need.
Thank you.
Wendell
