[mapserver-users] set COLOR to transparent?
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Mon May 3 09:54:02 EDT 2010
Not sure if this will work or not. The OFFSITE parameter is normally used with rasters to set pixel transparency. You could try something like:
OFFSITE 1 2 3
CLASS
EXPRESSION ...
COLOR 1 2 3
END
I don't know if the raster code looks for offsite pixels before *or* after classification. Still might have the reseting problem. I agree that this
is a desirable piece of functionality. Frank would know for sure what's possible in 5.6...
Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Wendell Turner [wendell at enflight.com]
Sent: Friday, April 30, 2010 4:34 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] set COLOR to transparent?
Is there a way to turn a pixel transparent? That is,
something like:
CLASS
EXPRESSION ([red] > 200 AND [green] > 200 AND [blue] > 200 )
TRANSPARENT
END
Or is there a way to set the pixel to the index of the
transparent entry in the color table?
Also, is there an 'ELSE' clause to the class/expression
statements? That is, if the expression fails, leave other
pixels alone. Using a class and an expression seems to
reset all other pixels.
Thanks,
Wendell
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
