[mapserver-users] Re: WMS and tiles cutting off
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon May 3 14:44:20 EDT 2010
If the query is optimized then try to find out real bottle neck. I believe that first step would be to throw away your client and test with shp2img and by having DEBUG 5 with all your layers. If you believe that the reason is due to symbols, then have a try by commenting out all the symbols you will soon know it for sure. I have not played with symbols myself but I can imagine that some sort of symbols are faster to render than others (truetype/pixmap/inline).
-Jukka Rahkonen-
Adam Eskreis wrote:
> Thank you for the response David.
> I have optimized the query all I can. I have optimized the query to the
point that even with all categories selected, the query has a run time of 52
ms. I can only assume that the issue lies with the generation of the
images. I will try to run it without the "IN" part of the query, but I
can't imagine that it'st he problem. I think the problem is that there are
a large number of symbols that need to be generated, and it's taking
mapserver a long time to load them in. Also, yes I have indexes on all
columns that I am calling in, and yes, they are all using the same SRS. I
am still trying a few more things, but I don't think it's the database query
that's causing the problem.
> On Fri, Apr 30, 2010 at 9:37 AM, Fawcett, David (MPCA) <
David.Fawcett at state.mn.us> wrote:
>> Adam,
>> It sounds like you have boiled the issue down to too much of a time lag
> between the time the query is executed and the image appears in the client.
>> Is it taking a long time for MapServer to draw the image, or is it the
> delivery of the image to the requesting machine and subsequent placement in
> the client?
>> If it is taking MapServer a long time, maybe there are some more data
> optimizations that you can do. Is there a better way to structure your
> data, can you do any pre-processing? Is it all in the same SRS, got
> attribute and spatial indexes? I have used the SQL IN for some apps with
> reasonable performance, but in the last 6 months or so, there were some
> posts on this list comparing the use of IN to a layer (or class?) filter.
> The latter solution was significantly faster.
>> If it is taking a long time to get to the client, then that is likely an
> infrastructure issue on either end.
>> If you want some more help digging in more deeply, post some more stats and
> mapfile snippets.
>> David.
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Adam Eskreis
> *Sent:* Thursday, April 29, 2010 4:24 PM
> *To:* Lime, Steve D (DNR)
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Re: WMS and tiles cutting off
> I tried doing ratio:1 unfortunately it doesn't seem like enough of a
> performance increase. Separate layers for each category is an option,
> however, there are over a hundred categories, and any combination of
> categories can be on at any given time, so this could prove to have
> performance issues of it's own. However, I thank you guys Steve and Kaipi
> for your advice. I think I am just going to go back to my old method, which
> was using php mapscript to generate the tiles, then each time the user
> selected new categories, purge the cache and remake the mapfile. It's not
> the ideal solution but it seems to be the only one.
> Thanks again,
> -Adam
> On Thu, Apr 29, 2010 at 3:50 PM, Lime, Steve D (DNR) <
> Steve.Lime at state.mn.us> wrote:
> Note that by default I believe openlayers will request an image that is
> *much* larger than what is visible. Setting the layers (OL) ratio:1 makes it
> the same size as the view port and that can speed up rendering considerably.
> Alternatively you could create a separate set of tiles for each category I
> suppose and switch OL layers as necessary...
> Steve
> ________________________________________
> From: mapserver-users-bounces at lists.osgeo.org [
> mapserver-users-bounces at lists.osgeo.org] On Behalf Of Adam Eskreis [
> aeskreis at gmail.com]
> Sent: Thursday, April 29, 2010 2:25 PM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Re: WMS and tiles cutting off
> Ok, I just gave an untiled layer a try, unfortunately though, due to the
> large amount of symbols being displayed on the screen, there is about a 2
> second delay every time the map is panned. My client will most certainly
> find this unacceptable. I have tried using smaller images, but I cannot
> sacrifice any more quality. I believe my database query to be as optimized
> as it can be (has about 50 ms runtime, I honestly don't think I can get it
> any lower than that).
> If these are the only options, is there something else besides WMS that you
> all would recommend using to solve this issue?
> Thanks,
> -Adam
> On Thu, Apr 29, 2010 at 2:54 PM, Lime, Steve D (DNR) <
> Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>> wrote:
> So use two layers. One for the background, use tilecache for that. Then use
> an untiled wms/mapserver layer for the overlayed points. - Steve
> From: mapserver-users-bounces at lists.osgeo.org<mailto:
> mapserver-users-bounces at lists.osgeo.org> [
> mapserver-users-bounces at lists.osgeo.org>] On Behalf Of Adam Eskreis [
> aeskreis at gmail.com<mailto:aeskreis at gmail.com>]
> Sent: Thursday, April 29, 2010 1:24 PM
> To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org
> I have thought about using tilecache with metatiling, however there is a
> caveat about this map that i forgot to mention in my main post, and it has
> to do with that "categories" parameter. Basically, each point/symbol on the
> map has an associated category in the database backend. I am using
> mapserver/WMS parameters to change the categories which are called. Each
> time the user selects a category, only the points in that category are
> shown. My query in the mapfile looks something like thi:
> SELECT point_geom,gid,symbol,angle FROM mapdata WHERE category
> IN(%CATEGORIES%)";
> And each time the user changes the categories, I use openlayers to merge
> new parameters, and input the new category values that should be used. Is
> tilecache still useable if I have a system like this set up?
> Thanks,
> -Adam
> On Thu, Apr 29, 2010 at 6:14 AM, kaipi <mapcollect at gmx.net<mailto:
> mapcollect at gmx.net><mailto:mapcollect at gmx.net<mailto:mapcollect at gmx.net>>>
> wrote:
> Hi,
> you can use http://tilecache.org/ Tilecache with the option metatiling
> enabled. With metatiling enabled Tilecache will fetch larger tiles (eg.
> 4096x4096) from Mapserver and will cut them into smaller tiles (eg.
> 256x256). It will also increase performance because Mapserver does not need
> to render tiles when they are already in cache.
> kaipi
> http://osgeo-org.1803224.n2.nabble.com/WMS-and-tiles-cutting-off-tp4978418p4979280.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> ><mailto:mapserver-users at lists.osgeo.org<mailto:
> mapserver-users at lists.osgeo.org>>
