[mapserver-users] Re: WMS and tiles cutting off
Adam Eskreis
aeskreis at gmail.com
Mon May 3 19:23:02 EDT 2010
Thank you for the advice Jukka. I tried just running shp2img. The results
are almost instant. I also tried using my client with the symbols turned
off, and the result was about half the load time. So I guess from this we
can assume that there is a certain amount of overhead that openlayers is
giving me, as well the symbols are causing some overhead. The only thing
is, what to do? I can't sacrifice any more quality on my symbols (whcih are
8 bit png images) and openlayers as far as I know is the best client out
there.
Things are starting to look grim
On Mon, May 3, 2010 at 2:44 PM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>wrote:
> Hi,
> If the query is optimized then try to find out real bottle neck. I believe
> that first step would be to throw away your client and test with shp2img and
> by having DEBUG 5 with all your layers. If you believe that the reason is
> due to symbols, then have a try by commenting out all the symbols you will
> soon know it for sure. I have not played with symbols myself but I can
> imagine that some sort of symbols are faster to render than others
> (truetype/pixmap/inline).
> -Jukka Rahkonen-
> Adam Eskreis wrote:
> > Thank you for the response David.
> > I have optimized the query all I can. I have optimized the query to the
> point that even with all categories selected, the query has a run time of
> 52
> ms. I can only assume that the issue lies with the generation of the
> images. I will try to run it without the "IN" part of the query, but I
> can't imagine that it'st he problem. I think the problem is that there are
> a large number of symbols that need to be generated, and it's taking
> mapserver a long time to load them in. Also, yes I have indexes on all
> columns that I am calling in, and yes, they are all using the same SRS. I
> am still trying a few more things, but I don't think it's the database
> query
> that's causing the problem.
> > On Fri, Apr 30, 2010 at 9:37 AM, Fawcett, David (MPCA) <
> David.Fawcett at state.mn.us> wrote:
> >> Adam,
> >> It sounds like you have boiled the issue down to too much of a time lag
> > between the time the query is executed and the image appears in the
> client.
> >> Is it taking a long time for MapServer to draw the image, or is it the
> > delivery of the image to the requesting machine and subsequent placement
> in
> > the client?
> >> If it is taking MapServer a long time, maybe there are some more data
> > optimizations that you can do. Is there a better way to structure your
> > data, can you do any pre-processing? Is it all in the same SRS, got
> > attribute and spatial indexes? I have used the SQL IN for some apps with
> > reasonable performance, but in the last 6 months or so, there were some
> > posts on this list comparing the use of IN to a layer (or class?) filter.
> > The latter solution was significantly faster.
> >> If it is taking a long time to get to the client, then that is likely an
> > infrastructure issue on either end.
> >> If you want some more help digging in more deeply, post some more stats
> and
> > mapfile snippets.
> >> David.
> > *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> > mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Adam Eskreis
> > *Sent:* Thursday, April 29, 2010 4:24 PM
> > *To:* Lime, Steve D (DNR)
> > *Cc:* mapserver-users at lists.osgeo.org
> > *Subject:* Re: [mapserver-users] Re: WMS and tiles cutting off
> > I tried doing ratio:1 unfortunately it doesn't seem like enough of a
> > performance increase. Separate layers for each category is an option,
> > however, there are over a hundred categories, and any combination of
> > categories can be on at any given time, so this could prove to have
> > performance issues of it's own. However, I thank you guys Steve and
> Kaipi
> > for your advice. I think I am just going to go back to my old method,
> which
> > was using php mapscript to generate the tiles, then each time the user
> > selected new categories, purge the cache and remake the mapfile. It's
> not
> > the ideal solution but it seems to be the only one.
> > Thanks again,
> > -Adam
> > On Thu, Apr 29, 2010 at 3:50 PM, Lime, Steve D (DNR) <
> > Steve.Lime at state.mn.us> wrote:
> > Note that by default I believe openlayers will request an image that is
> > *much* larger than what is visible. Setting the layers (OL) ratio:1 makes
> it
> > the same size as the view port and that can speed up rendering
> considerably.
> > Alternatively you could create a separate set of tiles for each category
> I
> > suppose and switch OL layers as necessary...
> > Steve
> > ________________________________________
> > From: mapserver-users-bounces at lists.osgeo.org [
> > mapserver-users-bounces at lists.osgeo.org] On Behalf Of Adam Eskreis [
> > aeskreis at gmail.com]
> > Sent: Thursday, April 29, 2010 2:25 PM
> > To: mapserver-users at lists.osgeo.org
> > Subject: Re: [mapserver-users] Re: WMS and tiles cutting off
> > Ok, I just gave an untiled layer a try, unfortunately though, due to the
> > large amount of symbols being displayed on the screen, there is about a 2
> > second delay every time the map is panned. My client will most certainly
> > find this unacceptable. I have tried using smaller images, but I cannot
> > sacrifice any more quality. I believe my database query to be as
> optimized
> > as it can be (has about 50 ms runtime, I honestly don't think I can get
> it
> > any lower than that).
> > If these are the only options, is there something else besides WMS that
> you
> > all would recommend using to solve this issue?
> > Thanks,
> > -Adam
> > On Thu, Apr 29, 2010 at 2:54 PM, Lime, Steve D (DNR) <
> > Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>> wrote:
> > So use two layers. One for the background, use tilecache for that. Then
> use
> > an untiled wms/mapserver layer for the overlayed points. - Steve
> > From: mapserver-users-bounces at lists.osgeo.org<mailto:
> > mapserver-users-bounces at lists.osgeo.org> [
> > mapserver-users-bounces at lists.osgeo.org>] On Behalf Of Adam Eskreis [
> > aeskreis at gmail.com<mailto:aeskreis at gmail.com>]
> > Sent: Thursday, April 29, 2010 1:24 PM
> > To: mapserver-users at lists.osgeo.org<mailto:
> > I have thought about using tilecache with metatiling, however there is a
> > caveat about this map that i forgot to mention in my main post, and it
> has
> > to do with that "categories" parameter. Basically, each point/symbol on
> the
> > map has an associated category in the database backend. I am using
> > mapserver/WMS parameters to change the categories which are called. Each
> > time the user selects a category, only the points in that category are
> > shown. My query in the mapfile looks something like thi:
> > SELECT point_geom,gid,symbol,angle FROM mapdata WHERE category
> > IN(%CATEGORIES%)";
> > And each time the user changes the categories, I use openlayers to merge
> > new parameters, and input the new category values that should be used.
> Is
> > tilecache still useable if I have a system like this set up?
> > Thanks,
> > -Adam
> > On Thu, Apr 29, 2010 at 6:14 AM, kaipi <mapcollect at gmx.net<mailto:
> > mapcollect at gmx.net><mailto:mapcollect at gmx.net<mailto:mapcollect at gmx.net
> > wrote:
> > Hi,
> > you can use http://tilecache.org/ Tilecache with the option
> metatiling
> > enabled. With metatiling enabled Tilecache will fetch larger tiles (eg.
> > 4096x4096) from Mapserver and will cut them into smaller tiles (eg.
> > 256x256). It will also increase performance because Mapserver does not
> need
> > to render tiles when they are already in cache.
> > kaipi
> > View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/WMS-and-tiles-cutting-off-tp4978418p4979280.html
> > Sent from the Mapserver - User mailing list archive at Nabble.com.
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org
> > ><mailto:mapserver-users at lists.osgeo.org<mailto:
> > mapserver-users at lists.osgeo.org>>
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100503/af9b8d76/attachment.html
