[mapserver-users] Mapserver's configuration - Support Oracle Spatial
Daiane Azevedo de Fraga
daiane.a.fraga at gmail.com
Tue May 4 13:08:49 EDT 2010
Hello!
I installed the MapServer 5.0.2 (in Debian) with support for Oracle Spatial
(--with-oraclespatial=$ORACLE_HOME). However, it does not work yet. Errors
are appearing in the logfile:
[Tue May 4 11:47:45 2010].697128 msDrawMap(): Image handling error. Failed
to draw layer named 'mapa_base'.
[Tue May 4 11:47:45 2010].700221 msOracleSpatialLayerClose(): OracleSpatial
error. OracleSpatial is not supported
MapServer version 5.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER SUPPORTS=THREADS
SUPPORTS=GEOS INPUT=EPPL7 INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
It worked on Windows!
Any idea...?
NOTE: MapServer did not find the files libnnz10.so and libclntsh.so.10.1, so
I created symbolic links to files in the folder $ORACLE_HOME/lib. Is this a
problem?
Thanks!
Daiane Fraga
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100504/e3ecae02/attachment.html
