Re: [mapserver-users] Mapserver's configuration - Support Oracle Spatial
Ivan Lucena
ivan.lucena at pmldnet.com
Tue May 4 13:27:01 EDT 2010
Hi Daiane,
Did you check the installation instruction on that page here: http://mapserver.org/installation/oracle.html
Once you are done that SDO_GEOMETRY and SDO_GEORASTER should work.
Regards,
Ivan
> -------Original Message-------
> From: Daiane Azevedo de Fraga <daiane.a.fraga at gmail.com>
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Mapserver's configuration - Support Oracle Spatial
> Sent: May 04 '10 12:08
> Hello!
> I installed the MapServer 5.0.2 (in Debian) with support for Oracle
> Spatial (--with-oraclespatial=$ORACLE_HOME). However, it does not work yet.
> Errors are appearing in the logfile:
> [Tue May 4 11:47:45 2010].697128 msDrawMap(): Image handling error.
> Failed to draw layer named 'mapa_base'.
> [Tue May 4 11:47:45 2010].700221 msOracleSpatialLayerClose():
> OracleSpatial error. OracleSpatial is not supported
> MapServer version 5.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER
> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=EPPL7 INPUT=ORACLESPATIAL INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> It worked on Windows!
> Any idea...?
> NOTE: MapServer did not find the files libnnz10.so and libclntsh.so.10.1,
> so I created symbolic links to files in the folder $ORACLE_HOME/lib. Is
> this a problem?
> Thanks!
> Daiane Fraga
> [LINK: compose.php?to=mapserver-users at lists.osgeo.org]
> [LINK: http://lists.osgeo.org/mailman/listinfo/mapserver-users]
