[mapserver-users] wms version 1.3 bbox problems
Travis Kirstine traviskirstine at gmail.com
Wed May 5 11:54:53 EDT 2010
I'm currently running ms 5.4.2 and am having difficulties with wms
version 1.3.  I am using MapInfo as the client and it seems that it is
hard coded wms version 1.3 if available from the service.  It seems
that there is bbox issue when passing GetMap request to the service.
Is there something I have to add to the mapfile to indicate the
correct bbox or projection?
MAP
        NAME "Montreal Map"
        SIZE 256 256
        STATUS OFF
        UNITS METERS
        EXTENT -180 -90 180 90
        IMAGECOLOR 155 203 231
        SHAPEPATH "/home/share1/data"
        IMAGETYPE JPEG
        RESOLUTION 96
        PROJECTION
                "init=epsg:4326"
        END
        WEB
                IMAGEPATH "/home/share1/data/map_images/"
                IMAGEURL "http://xxxxxxxxxxxx/"
                METADATA
                        "wms_onlineresource" "http://xxxxxxxxxxxxxxxxxxxxxxxxxx"
                        "wms_srs" "EPSG:32198 EPSG:2138 EPSG:32098
EPSG:4269 EPSG:4326 EPSG:54004" # updated by user
                        "wms_title" "Montreal Map" # defined by user
                        "wms_abstract" "" # defined by user
                        "ows_sld_enabled" "false"
                END
        END
        OUTPUTFORMAT
                NAME png
                DRIVER "GD/PNG"
                MIMETYPE "image/png"
                IMAGEMODE RGBA
                EXTENSION "png"
                TRANSPARENT ON
        END
        OUTPUTFORMAT
                NAME jpeg
                DRIVER "GD/JPEG"
                MIMETYPE "image/jpeg"
                IMAGEMODE RGB
                EXTENSION "jpg"
                FORMATOPTION "QUALITY=80"
        END
        LAYER
                NAME "Imagery_1"
                DATA
"/home/share1/www/openstream/mapfiles/xml/31_Imagery_lvl1.xml"
                METADATA
                        "wms_group_abstract" ""
                        "wms_group_title" "Imagery"
                        "wms_title" "Imagery_1"
                        "wms_extents" "-180 -85.05112877980659 180
85.0511287798066"
                END
                PROJECTION
                        "init=epsg:4326"
                END
                MINSCALE 295828775
                TYPE RASTER
                GROUP "Imagery_group"
                STATUS ON
                PROCESSING "CLOSE_CONNECTION=DEFER"
                PROCESSING "RESAMPLE=BILINEAR"
        END
END
