[mapserver-users] wms version 1.3 bbox problems
Yewondwossen Assefa yassefa at dmsolutions.ca
Wed May 5 12:15:12 EDT 2010
  What does the GetMap request looks like, specifically the bbox
coordinates and the projection?  For wms 1.3.0, bbox coordinates are
expected for projections such as espg:4326 to use the inverse axe order
(lat/long instead of long/lat)?
regards,
On 05/05/2010 11:54 AM, Travis Kirstine wrote:
> Hi,
> I'm currently running ms 5.4.2 and am having difficulties with wms
> version 1.3.  I am using MapInfo as the client and it seems that it is
> hard coded wms version 1.3 if available from the service.  It seems
> that there is bbox issue when passing GetMap request to the service.
> Is there something I have to add to the mapfile to indicate the
> correct bbox or projection?
> MAP
>          NAME "Montreal Map"
>          SIZE 256 256
>          STATUS OFF
>          UNITS METERS
>          EXTENT -180 -90 180 90
>          IMAGECOLOR 155 203 231
>          SHAPEPATH "/home/share1/data"
>          IMAGETYPE JPEG
>          RESOLUTION 96
>          PROJECTION
>                  "init=epsg:4326"
>          END
>          WEB
>                  IMAGEPATH "/home/share1/data/map_images/"
>                  IMAGEURL "http://xxxxxxxxxxxx/"
>                  METADATA
>                          "wms_onlineresource" "http://xxxxxxxxxxxxxxxxxxxxxxxxxx"
>                          "wms_srs" "EPSG:32198 EPSG:2138 EPSG:32098
> EPSG:4269 EPSG:4326 EPSG:54004" # updated by user
>                          "wms_title" "Montreal Map" # defined by user
>                          "wms_abstract" "" # defined by user
>                          "ows_sld_enabled" "false"
>                  END
>          END
>          OUTPUTFORMAT
>                  NAME png
>                  DRIVER "GD/PNG"
>                  MIMETYPE "image/png"
>                  IMAGEMODE RGBA
>                  EXTENSION "png"
>                  TRANSPARENT ON
>          END
>          OUTPUTFORMAT
>                  NAME jpeg
>                  DRIVER "GD/JPEG"
>                  MIMETYPE "image/jpeg"
>                  IMAGEMODE RGB
>                  EXTENSION "jpg"
>                  FORMATOPTION "QUALITY=80"
>          END
>          LAYER
>                  NAME "Imagery_1"
>                  DATA
> "/home/share1/www/openstream/mapfiles/xml/31_Imagery_lvl1.xml"
>                  METADATA
>                          "wms_group_abstract" ""
>                          "wms_group_title" "Imagery"
>                          "wms_title" "Imagery_1"
>                          "wms_extents" "-180 -85.05112877980659 180
> 85.0511287798066"
>                  END
>                  PROJECTION
>                          "init=epsg:4326"
>                  END
>                  MINSCALE 295828775
>                  TYPE RASTER
>                  GROUP "Imagery_group"
>                  STATUS ON
>                  PROCESSING "CLOSE_CONNECTION=DEFER"
>                  PROCESSING "RESAMPLE=BILINEAR"
>          END
> END
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
