[mapserver-users] wms version 1.3 bbox problems
Travis Kirstine
traviskirstine at gmail.com
Wed May 5 14:29:24 EDT 2010
It appears that the bbox in the reverse order for 1.3, is there a work around?
wms.php?cid=27&VERSION=1.3.0&REQUEST=GetMap&LAYERS=Imagery_group&STYLES=&CRS=EPSG:4269&BBOX=-180,-90,180,90&WIDTH=636&HEIGHT=318&FORMAT=image/png&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF&EXCEPTIONS=XML
HTTP/1.1" 200 166460 "-" "C:\\Program
Files\\MapInfo85\\Professional\\MAPINFOW.EXE"
On 5 May 2010 12:15, Yewondwossen Assefa <yassefa at dmsolutions.ca> wrote:
> Hi,
> What does the GetMap request looks like, specifically the bbox coordinates
> and the projection? For wms 1.3.0, bbox coordinates are expected for
> projections such as espg:4326 to use the inverse axe order (lat/long instead
> of long/lat)?
> regards,
> On 05/05/2010 11:54 AM, Travis Kirstine wrote:
>> Hi,
>> I'm currently running ms 5.4.2 and am having difficulties with wms
>> version 1.3. I am using MapInfo as the client and it seems that it is
>> hard coded wms version 1.3 if available from the service. It seems
>> that there is bbox issue when passing GetMap request to the service.
>> Is there something I have to add to the mapfile to indicate the
>> correct bbox or projection?
>> MAP
>> NAME "Montreal Map"
>> SIZE 256 256
>> STATUS OFF
>> UNITS METERS
>> EXTENT -180 -90 180 90
>> IMAGECOLOR 155 203 231
>> SHAPEPATH "/home/share1/data"
>> IMAGETYPE JPEG
>> RESOLUTION 96
>> PROJECTION
>> "init=epsg:4326"
>> END
>> WEB
>> IMAGEPATH "/home/share1/data/map_images/"
>> IMAGEURL "http://xxxxxxxxxxxx/"
>> METADATA
>> "wms_onlineresource"
>> "http://xxxxxxxxxxxxxxxxxxxxxxxxxx"
>> "wms_srs" "EPSG:32198 EPSG:2138 EPSG:32098
>> EPSG:4269 EPSG:4326 EPSG:54004" # updated by user
>> "wms_title" "Montreal Map" # defined by user
>> "wms_abstract" "" # defined by user
>> "ows_sld_enabled" "false"
>> END
>> END
>> OUTPUTFORMAT
>> NAME png
>> DRIVER "GD/PNG"
>> MIMETYPE "image/png"
>> IMAGEMODE RGBA
>> EXTENSION "png"
>> TRANSPARENT ON
>> END
>> OUTPUTFORMAT
>> NAME jpeg
>> DRIVER "GD/JPEG"
>> MIMETYPE "image/jpeg"
>> IMAGEMODE RGB
>> EXTENSION "jpg"
>> FORMATOPTION "QUALITY=80"
>> END
>> LAYER
>> NAME "Imagery_1"
>> DATA
>> "/home/share1/www/openstream/mapfiles/xml/31_Imagery_lvl1.xml"
>> METADATA
>> "wms_group_abstract" ""
>> "wms_group_title" "Imagery"
>> "wms_title" "Imagery_1"
>> "wms_extents" "-180 -85.05112877980659 180
>> 85.0511287798066"
>> END
>> PROJECTION
>> "init=epsg:4326"
>> END
>> MINSCALE 295828775
>> TYPE RASTER
>> GROUP "Imagery_group"
>> STATUS ON
>> PROCESSING "CLOSE_CONNECTION=DEFER"
>> PROCESSING "RESAMPLE=BILINEAR"
>> END
>> END
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Assefa Yewondwossen
> Software Analyst
> Email: yassefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
