[mapserver-users] wms version 1.3 bbox problems
Yewondwossen Assefa
yassefa at dmsolutions.ca
Wed May 5 15:08:54 EDT 2010
You could possibly look into using mapscript wrapper for WxS services
(http://mapserver.org/ogc/mapscript.html) and possibly change the
version programatically or the order of the bbox.
regards,
On 05/05/2010 2:29 PM, Travis Kirstine wrote:
> It appears that the bbox in the reverse order for 1.3, is there a work around?
> wms.php?cid=27&VERSION=1.3.0&REQUEST=GetMap&LAYERS=Imagery_group&STYLES=&CRS=EPSG:4269&BBOX=-180,-90,180,90&WIDTH=636&HEIGHT=318&FORMAT=image/png&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF&EXCEPTIONS=XML
> HTTP/1.1" 200 166460 "-" "C:\\Program
> Files\\MapInfo85\\Professional\\MAPINFOW.EXE"
> On 5 May 2010 12:15, Yewondwossen Assefa<yassefa at dmsolutions.ca> wrote:
>> Hi,
>> What does the GetMap request looks like, specifically the bbox coordinates
>> and the projection? For wms 1.3.0, bbox coordinates are expected for
>> projections such as espg:4326 to use the inverse axe order (lat/long instead
>> of long/lat)?
>> regards,
>> On 05/05/2010 11:54 AM, Travis Kirstine wrote:
>>> Hi,
>>> I'm currently running ms 5.4.2 and am having difficulties with wms
>>> version 1.3. I am using MapInfo as the client and it seems that it is
>>> hard coded wms version 1.3 if available from the service. It seems
>>> that there is bbox issue when passing GetMap request to the service.
>>> Is there something I have to add to the mapfile to indicate the
>>> correct bbox or projection?
>>> MAP
>>> NAME "Montreal Map"
>>> SIZE 256 256
>>> STATUS OFF
>>> UNITS METERS
>>> EXTENT -180 -90 180 90
>>> IMAGECOLOR 155 203 231
>>> SHAPEPATH "/home/share1/data"
>>> IMAGETYPE JPEG
>>> RESOLUTION 96
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> WEB
>>> IMAGEPATH "/home/share1/data/map_images/"
>>> IMAGEURL "http://xxxxxxxxxxxx/"
>>> METADATA
>>> "wms_onlineresource"
>>> "http://xxxxxxxxxxxxxxxxxxxxxxxxxx"
>>> "wms_srs" "EPSG:32198 EPSG:2138 EPSG:32098
>>> EPSG:4269 EPSG:4326 EPSG:54004" # updated by user
>>> "wms_title" "Montreal Map" # defined by user
>>> "wms_abstract" "" # defined by user
>>> "ows_sld_enabled" "false"
>>> END
>>> END
>>> OUTPUTFORMAT
>>> NAME png
>>> DRIVER "GD/PNG"
>>> MIMETYPE "image/png"
>>> IMAGEMODE RGBA
>>> EXTENSION "png"
>>> TRANSPARENT ON
>>> END
>>> OUTPUTFORMAT
>>> NAME jpeg
>>> DRIVER "GD/JPEG"
>>> MIMETYPE "image/jpeg"
>>> IMAGEMODE RGB
>>> EXTENSION "jpg"
>>> FORMATOPTION "QUALITY=80"
>>> END
>>> LAYER
>>> NAME "Imagery_1"
>>> DATA
>>> "/home/share1/www/openstream/mapfiles/xml/31_Imagery_lvl1.xml"
>>> METADATA
>>> "wms_group_abstract" ""
>>> "wms_group_title" "Imagery"
>>> "wms_title" "Imagery_1"
>>> "wms_extents" "-180 -85.05112877980659 180
>>> 85.0511287798066"
>>> END
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> MINSCALE 295828775
>>> TYPE RASTER
>>> GROUP "Imagery_group"
>>> STATUS ON
>>> PROCESSING "CLOSE_CONNECTION=DEFER"
>>> PROCESSING "RESAMPLE=BILINEAR"
>>> END
>>> END
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Assefa Yewondwossen
>> Software Analyst
>> Email: yassefa at dmsolutions.ca
>> http://www.dmsolutions.ca/
>> Phone: (613) 565-5056 (ext 14)
>> Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
