[mapserver-users] wms version 1.3 bbox problems
Guillaume Sueur
no-reply at neogeo-online.net
Wed May 5 15:20:15 EDT 2010
And don't forget to check that user-agent is MAPINFOW.EXE before doing
that, or you would screw up requests sent by OGC specs respectful clients.
If you want to change the order of coordinates, only do it for EPSG
codes between 4000 and 5000...
Regards,
Guillaume
Le 05/05/2010 21:08, Yewondwossen Assefa a écrit :
> You could possibly look into using mapscript wrapper for WxS services
> (http://mapserver.org/ogc/mapscript.html) and possibly change the
> version programatically or the order of the bbox.
> regards,
> On 05/05/2010 2:29 PM, Travis Kirstine wrote:
>> It appears that the bbox in the reverse order for 1.3, is there a work
>> around?
>> wms.php?cid=27&VERSION=1.3.0&REQUEST=GetMap&LAYERS=Imagery_group&STYLES=&CRS=EPSG:4269&BBOX=-180,-90,180,90&WIDTH=636&HEIGHT=318&FORMAT=image/png&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF&EXCEPTIONS=XML
>> HTTP/1.1" 200 166460 "-" "C:\\Program
>> Files\\MapInfo85\\Professional\\MAPINFOW.EXE"
>> On 5 May 2010 12:15, Yewondwossen Assefa<yassefa at dmsolutions.ca> wrote:
>>> Hi,
>>> What does the GetMap request looks like, specifically the bbox
>>> coordinates
>>> and the projection? For wms 1.3.0, bbox coordinates are expected for
>>> projections such as espg:4326 to use the inverse axe order (lat/long
>>> instead
>>> of long/lat)?
>>> regards,
>>> On 05/05/2010 11:54 AM, Travis Kirstine wrote:
>>>> Hi,
>>>> I'm currently running ms 5.4.2 and am having difficulties with wms
>>>> version 1.3. I am using MapInfo as the client and it seems that it is
>>>> hard coded wms version 1.3 if available from the service. It seems
>>>> that there is bbox issue when passing GetMap request to the service.
>>>> Is there something I have to add to the mapfile to indicate the
>>>> correct bbox or projection?
>>>> MAP
>>>> NAME "Montreal Map"
>>>> SIZE 256 256
>>>> STATUS OFF
>>>> UNITS METERS
>>>> EXTENT -180 -90 180 90
>>>> IMAGECOLOR 155 203 231
>>>> SHAPEPATH "/home/share1/data"
>>>> IMAGETYPE JPEG
>>>> RESOLUTION 96
>>>> PROJECTION
>>>> "init=epsg:4326"
>>>> END
>>>> WEB
>>>> IMAGEPATH "/home/share1/data/map_images/"
>>>> IMAGEURL "http://xxxxxxxxxxxx/"
>>>> METADATA
>>>> "wms_onlineresource"
>>>> "http://xxxxxxxxxxxxxxxxxxxxxxxxxx"
>>>> "wms_srs" "EPSG:32198 EPSG:2138 EPSG:32098
>>>> EPSG:4269 EPSG:4326 EPSG:54004" # updated by user
>>>> "wms_title" "Montreal Map" # defined by user
>>>> "wms_abstract" "" # defined by user
>>>> "ows_sld_enabled" "false"
>>>> END
>>>> END
>>>> OUTPUTFORMAT
>>>> NAME png
>>>> DRIVER "GD/PNG"
>>>> MIMETYPE "image/png"
>>>> IMAGEMODE RGBA
>>>> EXTENSION "png"
>>>> TRANSPARENT ON
>>>> END
>>>> OUTPUTFORMAT
>>>> NAME jpeg
>>>> DRIVER "GD/JPEG"
>>>> MIMETYPE "image/jpeg"
>>>> IMAGEMODE RGB
>>>> EXTENSION "jpg"
>>>> FORMATOPTION "QUALITY=80"
>>>> END
>>>> LAYER
>>>> NAME "Imagery_1"
>>>> DATA
>>>> "/home/share1/www/openstream/mapfiles/xml/31_Imagery_lvl1.xml"
>>>> METADATA
>>>> "wms_group_abstract" ""
>>>> "wms_group_title" "Imagery"
>>>> "wms_title" "Imagery_1"
>>>> "wms_extents" "-180 -85.05112877980659 180
>>>> 85.0511287798066"
>>>> END
>>>> PROJECTION
>>>> "init=epsg:4326"
>>>> END
>>>> MINSCALE 295828775
>>>> TYPE RASTER
>>>> GROUP "Imagery_group"
>>>> STATUS ON
>>>> PROCESSING "CLOSE_CONNECTION=DEFER"
>>>> PROCESSING "RESAMPLE=BILINEAR"
>>>> END
>>>> END
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> Assefa Yewondwossen
>>> Software Analyst
>>> Email: yassefa at dmsolutions.ca
>>> http://www.dmsolutions.ca/
>>> Phone: (613) 565-5056 (ext 14)
>>> Fax: (613) 565-0925
