[mapserver-users] Oracle Spatial and MAXFEATURES, not implemented?
Yewondwossen Assefa yassefa at dmsolutions.ca
Fri May 7 10:03:31 EDT 2010
This was done as part of the http://trac.osgeo.org/mapserver/ticket/2605
and is only available in trunk right now (for the upcoming 6.0 release).
regards,
On 07/05/2010 9:45 AM, Peter Hopfgartner wrote:
> I'm trying to limit the maximum number of features, as in the map file
> snippet below.
> MapServer is 5.6.3.
> Anyway, the number of features drawn is not limited, as expected, but
> thousands of shapes are processed.
> Indeed, enabling -all_debug 5, the query passed to Oracle looks like;
> msOracleSpatialLayerWhichShapes. Using this Sql to retrieve the data:
> SELECT pln_id, pln_id, the_geom FROM plant_data_map WHERE
> SDO_FILTER( the_geom, MDSYS.SDO_GEOMETRY(2003, :srid,
> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates ),'querytype=window') = 'TRUE'
> msOracleSpatialLayerWhichShapes. Bind values: srid:25832
> minx:666798.076923   miny:5169400.000000  maxx:667551.923077
> maxy:5170000.000000
> Indeed, almost 15,000 shapes arrive:
> msOracleSpatialLayerNextShape on layer 0x101363e0, row_num: 14934
> msOracleSpatialLayerNextShape on layer 0x101363e0, Fetched 0 more rows
> (14934 total)
> msOracleSpatialLayerFreeItemInfo was called.
> Peeking at the source in maporaclespatial.c, it seems that
> layer->maxfeatures is never read and no limitation, maybe looking like
> "ROWNUM<= layer->maxfeatures" is added to the SELECT statement.
> Regards,
> Peter
> MAPFILE SNIPPET:
> LAYER #----------------16-----------------
>          GROUP "pflanzennr_black_12"
>          NAME "Pflanzennr"
>          STATUS ON
>          TYPE POINT
>          PROJECTION
>                  "init=epsg:25832"
>          END
>          CONNECTIONTYPE oraclespatial
>          CONNECTION "{MYUSER}/{MYPASSWD}"
>          DATA "the_geom from plant_data_map using  unique pln_id srid
> 25832"
>          PROCESSING "CLOSE_CONNECTION=DEFER"
>          SIZEUNITS meters
>          LABELITEM "pln_id"
>          MAXFEATURES 20
>          TOLERANCE 1
>          POSTLABELCACHE TRUE
>          CLASS
>                  NAME "label"
>                  LABEL
>                          TYPE TRUETYPE
>                          PARTIALS TRUE
>                          FONT "verdana"
>                          COLOR 0 0 0
>                          OUTLINECOLOR 255 255 255
>                          SIZE 6
>                          MINSIZE 6
>                          MAXSIZE 8
>                          POSITION CR
>                          FORCE TRUE
>                  END
>          END
> END
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
