[mapserver-users] Oracle Spatial and MAXFEATURES, not implemented?
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Fri May 7 11:05:57 EDT 2010
On Fri, 2010-05-07 at 10:03 -0400, Yewondwossen Assefa wrote:
> This was done as part of the http://trac.osgeo.org/mapserver/ticket/2605
> and is only available in trunk right now (for the upcoming 6.0 release).
> regards,
Hello Yewondwossen.
Thank you for the pointer! I've applied the diff
http://trac.osgeo.org/mapserver/changeset/9593?format=diff&new=9593 to
the 5.6.3 source and it works perfectly!
Thank you and have a nice week end,
Peter
> On 07/05/2010 9:45 AM, Peter Hopfgartner wrote:
> > I'm trying to limit the maximum number of features, as in the map file
> > snippet below.
> > MapServer is 5.6.3.
> > Anyway, the number of features drawn is not limited, as expected, but
> > thousands of shapes are processed.
> > Indeed, enabling -all_debug 5, the query passed to Oracle looks like;
> > msOracleSpatialLayerWhichShapes. Using this Sql to retrieve the data:
> > SELECT pln_id, pln_id, the_geom FROM plant_data_map WHERE
> > SDO_FILTER( the_geom, MDSYS.SDO_GEOMETRY(2003, :srid,
> > NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates ),'querytype=window') = 'TRUE'
> > msOracleSpatialLayerWhichShapes. Bind values: srid:25832
> > minx:666798.076923   miny:5169400.000000  maxx:667551.923077
> > maxy:5170000.000000
> > Indeed, almost 15,000 shapes arrive:
> > msOracleSpatialLayerNextShape on layer 0x101363e0, row_num: 14934
> > msOracleSpatialLayerNextShape on layer 0x101363e0, Fetched 0 more rows
> > (14934 total)
> > msOracleSpatialLayerFreeItemInfo was called.
> > Peeking at the source in maporaclespatial.c, it seems that
> > layer->maxfeatures is never read and no limitation, maybe looking like
> > "ROWNUM<= layer->maxfeatures" is added to the SELECT statement.
> > Regards,
> > Peter
> > MAPFILE SNIPPET:
> > LAYER #----------------16-----------------
> >          GROUP "pflanzennr_black_12"
> >          NAME "Pflanzennr"
> >          STATUS ON
> >          TYPE POINT
> >          PROJECTION
> >                  "init=epsg:25832"
> >          END
> >          CONNECTIONTYPE oraclespatial
> >          CONNECTION "{MYUSER}/{MYPASSWD}"
> >          DATA "the_geom from plant_data_map using  unique pln_id srid
> > 25832"
> >          PROCESSING "CLOSE_CONNECTION=DEFER"
> >          SIZEUNITS meters
> >          LABELITEM "pln_id"
> >          MAXFEATURES 20
> >          TOLERANCE 1
> >          POSTLABELCACHE TRUE
> >          CLASS
> >                  NAME "label"
> >                  LABEL
> >                          TYPE TRUETYPE
> >                          PARTIALS TRUE
> >                          FONT "verdana"
> >                          COLOR 0 0 0
> >                          OUTLINECOLOR 255 255 255
> >                          SIZE 6
> >                          MINSIZE 6
> >                          MAXSIZE 8
> >                          POSITION CR
> >                          FORCE TRUE
> >                  END
> >          END
> > END
Dott. Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
Email: peter.hopfgartner at r3-gis.com
Tel. : +39 0473 494949
Fax  : +39 0473 069902
www  : http://www.r3-gis.com
XING : http://www.xing.com/go/invita/8917535
