[mapserver-users] Testing KML support
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Fri May 7 12:23:53 EDT 2010
I'm would like to look at the KML functionality in the current MapServer
trunk.
There does not seem to be any specific option in configure, so I enabled
it by setting the environment variable CPPFLAGS:
$ export CPPFLAGS=-DUSE_KML
$ ./configure --with-proj --with-postgis --with-cairovim
--with-xml2-config=/usr/bin/xml2-config
$ make
The resulting shp2img has a lot of Kml-related symbols in it:
$ nm shp2img | grep -i kml | wc -l
71
Anyway, KML does not seem to be oin the OUTPUT formats list:
[peter.hopfgartner at vm-centos5-64-1 mapserver]$ ./shp2img -v
MapServer version 5.7-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER INPUT=JPEG INPUT=POSTGIS INPUT=SHAPEFILE
Indeed, trying to produce some KML from a map file, I get:
$ /usr/local/bin/shp2img -i KML -m kml_test.map > test.kml
loadOutputFormat(): General error message. OUTPUTFORMAT clause
references driver KML, but this driver isn't configured. <br>
Am I missing something?
Regards,
Peter
Dott. Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
Email: peter.hopfgartner at r3-gis.com
Tel. : +39 0473 494949
Fax : +39 0473 069902
www : http://www.r3-gis.com
XING : http://www.xing.com/go/invita/8917535
