[mapserver-users] Testing KML support
    Yewondwossen Assefa
    yassefa at dmsolutions.ca
    Fri May  7 14:02:22 PDT 2010
Hi Peter,
There is supposed to be --with-kml.
I have added the OUTPUT=KML if built with the flag.
Note that the driver is still in development/cleanup state. I will
update the RFC  (http://mapserver.org/development/rfc/ms-rfc-58.html)
once this phase is over.
regards,
On 07/05/2010 12:23 PM, Peter Hopfgartner wrote:
> Hi,
> I'm would like to look at the KML functionality in the current MapServer
> trunk.
> There does not seem to be any specific option in configure, so I enabled
> it by setting the environment variable CPPFLAGS:
> $ export CPPFLAGS=-DUSE_KML
> $ ./configure --with-proj --with-postgis --with-cairovim
> --with-xml2-config=/usr/bin/xml2-config
> $ make
> The resulting shp2img has a lot of Kml-related symbols in it:
> $ nm shp2img | grep -i kml | wc -l
> 71
> Anyway, KML does not seem to be oin the OUTPUT formats list:
> [peter.hopfgartner at vm-centos5-64-1 mapserver]$ ./shp2img -v
> MapServer version 5.7-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=WMS_SERVER INPUT=JPEG INPUT=POSTGIS INPUT=SHAPEFILE
> Indeed, trying to produce some KML from a map file, I get:
> $ /usr/local/bin/shp2img -i KML -m kml_test.map>  test.kml
> loadOutputFormat(): General error message. OUTPUTFORMAT clause
> references driver KML, but this driver isn't configured.<br>
> Am I missing something?
> Regards,
> Peter
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
More information about the MapServer-users
