[mapserver-users] Re: Problem with OpenStreetMap, osm2pgsql, MapServer, OpenLayers and epsg=900913
Edward Mac Gillavry emacgillavry at hotmail.com
Sun May 9 13:52:23 EDT 2010
Hi Roshni,
You are almost there it seems! Try extending the DATA statement such that it states the srid (Spatial Reference System Identifier) explicitly:
    DATA "way from planet_osm_line using unique gid using srid=900913"
Hope this helps.
Regards,
Edward Mac Gillavry
> From: roshni.aruna at gmail.com
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Re: Problem with OpenStreetMap, osm2pgsql, MapServer, OpenLayers and epsg=900913
> Hi Milo, thanks for your reply.
> I have gone through the link you sent and after doing many tests i decided
> to start again from zero without WMS. I downloaded the Frida_tutorial and
> implemented it and it works perfectly fine (connecting to postgis and
> reading info from the db).
> After checking this, i just copy-pasted everything and just changed the info
> of the connection and the table from where get the data and again the image
> comes blank, so i guess the problem is between the db and the projection.
> This is my new map file.
> MAP
>   IMAGETYPE   JPEG
>   EXTENT       3428000 5787000 3444000 5800000
>   SIZE        600 600
>   IMAGECOLOR  100 100 100
>   SHAPEPATH   "C:/ms4w/apps/palmarouting/data"
> SYMBOLSET    "C:/ms4w/apps/palmarouting/symbols.sym"
>   FONTSET     "C:/ms4w/apps/palmarouting/fonts/fonts.list"
>   DEBUG 5
>   CONFIG "MS_ERRORFILE" "C:\ms4w\apps\palmarouting\ms_error.txt"
>   WEB
>   TEMPLATE "template.html"
>     #IMAGEPATH "C:/ms4w/Apache/htdocs/tmp/"
> 	IMAGEPATH "C:/ms4w/apps/palmarouting/tmp/"
>     IMAGEURL  "C:/ms4w/apps/palmarouting/tmp/"
>   END
>   PROJECTION
>    "init=epsg:900913"
>   END
>   LAYER
>     NAME "roads"
>     TYPE LINE
>    CONNECTION "user=postgres password=postgres dbname=gis host=localhost
> port=5432"
>    CONNECTIONTYPE postgis
>    DATA "way from planet_osm_line using unique gid"
>    STATUS DEFAULT
>   #LABELITEM 'strname'
>   CLASSITEM    'highway'
>         CLASS
>         	  EXPRESSION '1'
>         	  STYLE
>         	  COLOR	255 0 0
> 			  SIZE 6
>         	  END
>         END
>       CLASS
> 	       EXPRESSION '3'
> 	       STYLE
> 		     COLOR	0 255 0
> 	       END
>       END
>       CLASS
> 	       EXPRESSION /./
> 	       STYLE
> 		     COLOR	200 200 200
> 	       END
>       END
> END
>   LAYER
>       NAME "path"
> port=5432"
>     STATUS ON
>       TYPE LINE
>       CLASS
>         NAME "path"
> 	STYLE
> 	SYMBOL 'circle'
> COLOR 255 0 0
> SIZE 8
> 	END
>       END
> END
> END
> The only difference i can see between the Frida db and mine is that in
> Fridadb the srid set in the geometry_columns is set to -1, but in mine its
> 900913. I have tried to apply this diff in my map file but with no success
> What can i do??? Thanks a lot!!
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-with-OpenStreetMap-osm2pgsql-MapServer-OpenLayers-and-epsg-900913-tp5022925p5026547.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100509/194ef762/attachment.html
