[mapserver-users] wms layer query
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Wed May 12 11:24:07 EDT 2010
I fear I cannot help with the problem itself but I suppose there are two non-standard things in the GetFeatureInfo query:
- WMS layer names must not start with a number
- layers should be included also in GetFeatureInfo (not sure about this)
-Jukka Rahkonen-
Eric Weisbender wrote:
> Thanks Dave,
> I have tried a direct getFeatureInfo request and it works great... "http://rmgsc.cr.usgs.gov/arcgis/services/nhss_haz/MapServer/WMSServer?service=WMS&version=1.1.1&request=GetFeatureInfo&SRS=EPSG:4326&BBOX=-159.845000,20.809000,-72.815000,67.239000&query_layers=1&WIDTH=1&HEIGHT=1&X=1&Y=1&info_format=text/html&".  When I query it through my MapServer I get the following error... " msQueryByRect(): Search returned no results. No matching record(s) found."  I am using MapServer Version 5.2.2 and the WMS service is a USGS service available in both WMS Version 1.1.1 and 1.3.0.  I'm wondering if there are some compatibility issues and if anyone has a working example I might take a look at.  Again, thanks in advance.
EW
>>> "Fawcett, David (MPCA)" <David.Fawcett at state.mn.us> 5/10/2010 7:33 AM >>>
Have you tried a direct getFeatureInfo request from a browser?
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Eric Weisbender
Sent: Friday, May 07, 2010 2:19 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] wms layer query
Hello,
I have a wms layer defined in my map file coming from a USGS service that is supposed to be queryable  but when I query it I get nothing in return.  It draws fine and the GetCapabilities request says Layer queryable="1".  I wondering if it's my layer definition or if you just can't do this in basic mapserver.  Below is my layer def and any help is beer worthy.  Thanks in advance.
LAYER
  NAME "firetest"
  METADATA
    "wms_srs"             "EPSG:4326"
    "wms_name"            "1"
    "wms_server_version"  "1.1.1"
    "wms_format"          "image/png"
	"wms_title" "1"
    "wfs_title" "1"
	"wms_metadataurl_format" "text/html"
	 gml_include_items "all"
     wms_include_items "all"
 END
  STATUS OFF
  TYPE RASTER
  #MINSCALE 3800
  CONNECTIONTYPE WMS
  CONNECTION "http://rmgsc.cr.usgs.gov/arcgis/services/nhss_haz/MapServer/WMSServer?service=WMS&version=1.1.1&request=GetMap&layers=1&styles=defalut&transparent=TRUE&format=image/png"
  PROJECTION
  "init=epsg:4326"
  END
  CLASS
    NAME "fire wms test"
	KEYIMAGE '/data/gis/www/html/ms_common/fire.png'
  END
  TEMPLATE "http://gis.hq.wapa.gov/ms_common/fires.html"
  HEADER "http://gis.hq.wapa.gov/ms_common/fires_header.html"
  FOOTER "http://gis.hq.wapa.gov/ms_common/fires_footer.html"
  TOLERANCE 10
END
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
