[mapserver-users] compilation error
Roger André randre at gmail.com
Thu May 13 21:14:26 EDT 2010
Try installing the following ogdi packages with apt-get:
libogdi3.2 - Open Geographic Datastore Interface Library -- library
libogdi3.2-dev - Open Geographic Datastore Interface Library -- development
ogdi-bin - Open Geographic Datastore Interface Library -- utilities
No idea if that will do the trick though.  I've never seen that particular
error before.
Roger
On Wed, May 12, 2010 at 11:36 AM, pablo lopez <plablo09 at gmail.com> wrote:
> Hi List, Im building mapserver 5.6.3 on a ubuntu box. The config script I'm
> using is:
> ./configure     --prefix=/usr \
>         --with-ogr=/usr/bin/gdal-config \
>                 --with-gdal=/usr/bin/gdal-config \
>                 --with-httpd=/usr/sbin/apache2 \
>                 --with-wfsclient \
>         --with-fribidi \
>                 --with-wmsclient \
>         --with-wfs \
>         --with-pdf \
>                 --enable-debug \
>                 --with-curl-config=/usr/bin/curl-config \
>                 --with-proj=/usr \
>                 --with-tiff \
>                 --with-gd \
>                 --with-jpeg \
>         --with-png=/usr/lib \
>                 --with-freetype=/usr/lib \
>                 --with-threads \
>                 --with-wcs \
>                 --with-postgis=/usr/bin/pg_config \
>                 --with-geos=/usr/bin/geos-config \
>                 --with-libiconv=/usr/lib \
>         --with-php=/usr/include/php5 \
>                 --with-agg
>  The config output is:
> MapServer is now configured for
>  -------------- Compiler Info -------------
>   C compiler:                gcc -g  -fPIC -Wall
>   C++ compiler:              g++ -g  -fPIC -Wall
>   Debug:                     -g
>   Generic NINT:
>  -------------- Renderer Settings ---------
>   OpenGL support:
>   zlib support:              -DUSE_ZLIB
>   png support:
>   palette rgba png support:
>   jpeg support:
>   iconv support:             -DUSE_ICONV
>   AGG support:               -DUSE_AGG
>   Cairo (SVG,PDF) support:
>   Ming(flash) support:
>   PDFLib support:            -DUSE_PDF
>  -------------- Support Libraries ---------
>   Proj.4 support:            -DUSE_PROJ
>   Libxml2 support:           -DUSE_LIBXML2
>   FriBidi support:
>   Curl support:              -DUSE_CURL
>   FastCGI support:
>   Threading support:         -DUSE_THREAD
>   GEOS support:              -DUSE_GEOS -DGEOS_HAS_SIMPLIFY
>  -------------- Data Format Drivers -------
>   native tiff support:       -DUSE_TIFF
>   PostGIS support:           -DUSE_POSTGIS
>   EPPL7 support:             -DUSE_EPPL
>   ArcSDE support:
>   OGR support:               -DUSE_OGR
>   GDAL support:              -DUSE_GDAL
>   Oracle Spatial support:
>  -------------- OGC Services --------------
>   WMS Server:                -DUSE_WMS_SVR
>   WMS Client:                -DUSE_WMS_LYR
>   WFS Server:                -DUSE_WFS_SVR
>   WFS Client:                -DUSE_WMS_LYR
>   WCS Server:                -DUSE_WCS_SVR
>   SOS Server:
>  -------------- MapScript -----------------
>   PHP MapScript:             yes
> Now, when i run make, it ends up with the following error:
> shp2img.c:33: warning: ‘cvsid_aw’ defined but not used
> g++ -g  -fPIC -Wall     -DHAVE_VSNPRINTF -DNEED_STRLCAT
> -DNEED_STRRSTR        -DUSE_WMS_LYR -DUSE_WFS_LYR  -DUSE_LIBXML2 -DUSE_CURL
> -DUSE_WCS_SVR -DUSE_WFS_SVR -DUSE_WMS_SVR    -DUSE_POSTGIS -DUSE_TIFF
> -DUSE_GDAL -DUSE_OGR -DUSE_GEOS -DGEOS_HAS_SIMPLIFY  -DUSE_THREAD -DUSE_PROJ
> -DUSE_EPPL  -DUSE_AGG   -DUSE_PDF  -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG
> -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR
> -DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB     -I/usr/include
> -I/usr/include/freetype2    -I/usr/include     -I/usr/include/gdal
> -I/usr/include/postgresql     -I/usr/include    -I/usr/include/libxml2
> shp2img.o  -L. -lmapserver -lgd -L/usr/lib64 -lgd -ljpeg -L/usr/lib
> -lfreetype -L/usr/lib -lpng -lz -lXpm -lX11     -lpdf -ltiff -ljpeg
> -L/usr/lib -lfreetype -L/usr/lib -lpng -lz -lXpm -lX11  -L/usr/lib64 -lproj
> -ljpeg -L/usr/lib -lpng  -L/usr/lib -lgdal1.6.0 -L/usr/lib -lgeos_c
> -I/usr/include -lsqlite3 -lodbc -lodbcinst -L/usr/lib -lexpat -L/usr/lib
> -lxerces-c -lpthread -ljasper -lhdf5 -lmfhdf -ldf -logdi -lgif -ljpeg -lpng
> -lnetcdf -lpq -L/usr/lib -lpq -lz -lpthread -lm -lrt -ldl -lcurl
> -Wl,-Bsymbolic-functions -rdynamic -L/usr/lib/mysql -lmysqlclient
> -L/usr/lib -lpq -lpgport -lxslt -lxml2 -lpam -lssl -lcrypto -lkrb5 -lcom_err
> -lgssapi_krb5 -lz -lreadline -lcrypt -ldl -lm   -lcurl  -L/usr/lib -lgeos_c
> -lpthread -L -lc  -lz -lxml2  -lm -lstdc++    -o shp2img
> /usr/bin/ld: cannot find -logdi
> collect2: ld returned 1 exit status
> make: *** [shp2img] Error 1
> I'm lost here, any help is appreciated
> Thanks
> Pablo
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100513/8dc91ae6/attachment.html
