[mapserver-users] compilation error
pablo lopez
plablo09 at gmail.com
Fri May 14 10:02:22 EDT 2010
Thanks Roger Installing libogdi3.2-dev certainly solved the first issue,
then I had a problem with libpam, installing the -dev package solved that
issue, so now I succesfully compiled an installed mapserver!
Thanks a lot for your help.
Regards
P
On Thu, May 13, 2010 at 8:14 PM, Roger André <randre at gmail.com> wrote:
> Try installing the following ogdi packages with apt-get:
> libogdi3.2 - Open Geographic Datastore Interface Library -- library
> libogdi3.2-dev - Open Geographic Datastore Interface Library -- development
> ogdi-bin - Open Geographic Datastore Interface Library -- utilities
> No idea if that will do the trick though. I've never seen that particular
> error before.
> Roger
> On Wed, May 12, 2010 at 11:36 AM, pablo lopez <plablo09 at gmail.com> wrote:
>> Hi List, Im building mapserver 5.6.3 on a ubuntu box. The config script
>> I'm using is:
>> ./configure --prefix=/usr \
>> --with-ogr=/usr/bin/gdal-config \
>> --with-gdal=/usr/bin/gdal-config \
>> --with-httpd=/usr/sbin/apache2 \
>> --with-wfsclient \
>> --with-fribidi \
>> --with-wmsclient \
>> --with-wfs \
>> --with-pdf \
>> --enable-debug \
>> --with-curl-config=/usr/bin/curl-config \
>> --with-proj=/usr \
>> --with-tiff \
>> --with-gd \
>> --with-jpeg \
>> --with-png=/usr/lib \
>> --with-freetype=/usr/lib \
>> --with-threads \
>> --with-wcs \
>> --with-postgis=/usr/bin/pg_config \
>> --with-geos=/usr/bin/geos-config \
>> --with-libiconv=/usr/lib \
>> --with-php=/usr/include/php5 \
>> --with-agg
>> The config output is:
>> MapServer is now configured for
>> -------------- Compiler Info -------------
>> C compiler: gcc -g -fPIC -Wall
>> C++ compiler: g++ -g -fPIC -Wall
>> Debug: -g
>> Generic NINT:
>> -------------- Renderer Settings ---------
>> OpenGL support:
>> zlib support: -DUSE_ZLIB
>> png support:
>> palette rgba png support:
>> jpeg support:
>> iconv support: -DUSE_ICONV
>> AGG support: -DUSE_AGG
>> Cairo (SVG,PDF) support:
>> Ming(flash) support:
>> PDFLib support: -DUSE_PDF
>> -------------- Support Libraries ---------
>> Proj.4 support: -DUSE_PROJ
>> Libxml2 support: -DUSE_LIBXML2
>> FriBidi support:
>> Curl support: -DUSE_CURL
>> FastCGI support:
>> Threading support: -DUSE_THREAD
>> GEOS support: -DUSE_GEOS -DGEOS_HAS_SIMPLIFY
>> -------------- Data Format Drivers -------
>> native tiff support: -DUSE_TIFF
>> PostGIS support: -DUSE_POSTGIS
>> EPPL7 support: -DUSE_EPPL
>> ArcSDE support:
>> OGR support: -DUSE_OGR
>> GDAL support: -DUSE_GDAL
>> Oracle Spatial support:
>> -------------- OGC Services --------------
>> WMS Server: -DUSE_WMS_SVR
>> WMS Client: -DUSE_WMS_LYR
>> WFS Server: -DUSE_WFS_SVR
>> WFS Client: -DUSE_WMS_LYR
>> WCS Server: -DUSE_WCS_SVR
>> SOS Server:
>> -------------- MapScript -----------------
>> PHP MapScript: yes
>> Now, when i run make, it ends up with the following error:
>> shp2img.c:33: warning: ‘cvsid_aw’ defined but not used
>> g++ -g -fPIC -Wall -DHAVE_VSNPRINTF -DNEED_STRLCAT
>> -DNEED_STRRSTR -DUSE_WMS_LYR -DUSE_WFS_LYR -DUSE_LIBXML2 -DUSE_CURL
>> -DUSE_WCS_SVR -DUSE_WFS_SVR -DUSE_WMS_SVR -DUSE_POSTGIS -DUSE_TIFF
>> -DUSE_GDAL -DUSE_OGR -DUSE_GEOS -DGEOS_HAS_SIMPLIFY -DUSE_THREAD -DUSE_PROJ
>> -DUSE_EPPL -DUSE_AGG -DUSE_PDF -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG
>> -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR
>> -DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB -I/usr/include
>> -I/usr/include/freetype2 -I/usr/include -I/usr/include/gdal
>> -I/usr/include/postgresql -I/usr/include -I/usr/include/libxml2
>> shp2img.o -L. -lmapserver -lgd -L/usr/lib64 -lgd -ljpeg -L/usr/lib
>> -lfreetype -L/usr/lib -lpng -lz -lXpm -lX11 -lpdf -ltiff -ljpeg
>> -L/usr/lib -lfreetype -L/usr/lib -lpng -lz -lXpm -lX11 -L/usr/lib64 -lproj
>> -ljpeg -L/usr/lib -lpng -L/usr/lib -lgdal1.6.0 -L/usr/lib -lgeos_c
>> -I/usr/include -lsqlite3 -lodbc -lodbcinst -L/usr/lib -lexpat -L/usr/lib
>> -lxerces-c -lpthread -ljasper -lhdf5 -lmfhdf -ldf -logdi -lgif -ljpeg -lpng
>> -lnetcdf -lpq -L/usr/lib -lpq -lz -lpthread -lm -lrt -ldl -lcurl
>> -Wl,-Bsymbolic-functions -rdynamic -L/usr/lib/mysql -lmysqlclient
>> -L/usr/lib -lpq -lpgport -lxslt -lxml2 -lpam -lssl -lcrypto -lkrb5 -lcom_err
>> -lgssapi_krb5 -lz -lreadline -lcrypt -ldl -lm -lcurl -L/usr/lib -lgeos_c
>> -lpthread -L -lc -lz -lxml2 -lm -lstdc++ -o shp2img
>> /usr/bin/ld: cannot find -logdi
>> collect2: ld returned 1 exit status
>> make: *** [shp2img] Error 1
>> I'm lost here, any help is appreciated
>> Thanks
>> Pablo
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100514/9609519a/attachment-0001.html
