Re: [mapserver-users] Re: loadLayer(): Unknown identifier. Parsing error near (â):(line 662128)
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue May 18 07:31:25 EDT 2010
Stefan Schwarzer wrote:
> Ok, after thorough testing it seems indeed to be one special character there
> (although not an â). Cheers.
I was just about to respond to you, glad you solved it.  For the record,
when I have such a large mapfile and run into errors, I find the best
way to debug is to start removing layers, try shp2img, remove more
layers, try shp2img again, etc.
Also for the record, the hardcoded limit on layers, classes, styles, and
symbols were removed in MapServer 5.0.  This is documented at the bottom
of http://www.mapserver.org/mapfile/index.html#mapfile
I hope this information helps the next person debug their mapfile.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
