[mapserver-users] HDF Data projection in MapServer
Reddem
venkat.shesu at gmail.com
Tue May 18 07:44:11 EDT 2010
Hi Everybody,
I am trying to display HDF files using MapServer, and upto some extent
i have done it. Still i am facing problem with the projection of map.
and MapFile Layer looks like this:
LAYER
NAME wise_io
#DATA 'o.tif'
DATA
'HDF5:"C:/ms4w/apps/HDFData/data/output.h5"://Mapped_-_Composited_mapped'
DUMP TRUE
TYPE RASTER
STATUS ON
CLASSITEM "[pixel]"
CLASS
EXPRESSION ([pixel] > 0)
STYLE
COLOR 0 0 255
END
END
PROJECTION
END
END
and GDAL INFO for used HDF data is :
Driver: HDF5Image/HDF5 Dataset
Files: none associated
Size is 3630, 2530
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AUTHORITY["EPSG","4326"]]
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 2530.0)
Upper Right ( 3630.0, 0.0)
Lower Right ( 3630.0, 2530.0)
Center ( 1815.0, 1265.0)
Band 1 Block=3630x1 Type=Float32, ColorInterp=Undefined
Metadata:
Mapped - Composited mapped:Projection Category=IDL
Mapped - Composited mapped:Projection Name=Cylindrical
Mapped - Composited mapped:Source=A2010021053000_CHL.L2_LAC
Mapped - Composited mapped:units=mg m^-3
Mapped - Composited mapped:Slope=1.000000
Mapped - Composited mapped:Intercept=0.000000
Mapped - Composited mapped:Scaling=linear
Mapped - Composited mapped:Limit=4 62 27 95
Mapped - Composited mapped:Projection ID=8
Mapped - Composited mapped:Latitude Center=0
Mapped - Composited mapped:Longitude Center=78.5
Mapped - Composited mapped:Isotropic=1
Mapped - Composited mapped:Rotation=0
Mapped - Composited mapped:Position=0 0 1 1
Mapped - Composited mapped:Scale=0
Mapped - Composited mapped:Central_Azimuth=0
Mapped - Composited mapped:HDF4_OBJECT_TYPE=SDS
Mapped - Composited mapped:HDF4_OBJECT_NAME=Mapped - Composited mapped
Mapped - Composited mapped:HDF4_REF_NUM=2d
I have created the GeoTiff using gdal_translate and projected it and
it works well.
>> gdal_translate -ot Byte -of GTiff -b 1 -a_ullr 62 4 95 27
>> HDF5:"output.h5"://Mapped_-_Composited_mapped o.tif.
I am facing problem with projection of HDF data set which is 1 KM
gridded dataset. and as without defining Projection Derivative it is
showing somewhere else in the map. can anyone help me in this regard
to define Projection section of HDF data layer.
with regards
Venkat
View this message in context: http://osgeo-org.1803224.n2.nabble.com/HDF-Data-projection-in-MapServer-tp5069580p5069580.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
