[mapserver-users] wfs error <gml:null>missing</gml:null>
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed May 19 06:18:34 EDT 2010
Everything seems to be OK. Your layer is visible through WMS, getCapabilities works as well as describeFeatureType. Only odd thing is the getCapabilities informs that the featureType is in EPSG:900913, but I do not understand how it is possible:
<FeatureType>
<Name>ACESAP_field_data</Name>
<Title>ACESAP_field_data</Title>
<SRS>EPSG:900913</SRS>
<LatLongBoundingBox minx="7.23965" miny="40.4057" maxx="15.9559" maxy="46.9069"/>
</FeatureType>
-Jukka-
> -----Alkuperäinen viesti-----
> Lähettäjä: Luca Delucchi [mailto:lucadeluge at gmail.com]
> Lähetetty: 19. toukokuuta 2010 12:45
> Vastaanottaja: Rahkonen Jukka
> Kopio: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] wfs error <gml:null>missing</gml:null>
> 2010/5/19 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
> > Hi,
> hi, thank's for your fast reply
> > I believe it is not an error, it is just an empty
> collection. Perhaps
> > you have not done all that is needed to activate the WFS gml output,
> > like adding to LAYER definitions DUMP TRUE and
> "gml_include_items". Or
> > if you used some spatial filter it could have been outside the area
> > covered by your data.
> I already set DUMP TRUE and gml_include_items, and I use none spatial
> filter, my layer configuration is this
> LAYER
> NAME "ACESAP_field_data"
> TYPE POINT
> STATUS on
> CONNECTIONTYPE POSTGIS
> CONNECTION "dbname=**** user=*****
> password=***** host=localhost"
> DATA "geom from tabella_wfs using unique id
> using srid=4326"
> DUMP TRUE
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> STYLE
> SYMBOL 'circle1'
> OUTLINECOLOR 238 201 0
> END
> END
> METADATA
> "wfs_title" "ACESAP_field_data"
> "gml_featureid" "id"
> "wfs_srs" "EPSG:4326"
> "gml_include_items" "all"
> END
> END
> > -Jukka Rahkonen-
> cheers
> Luca
