[mapserver-users] help(symbolset)
Stephen Woodbridge woodbri at swoodbridge.com
Mon May 24 20:25:54 EDT 2010
Ricardo,
You must make sure the your symbolset files all have the token
"SYMBOLSET" at the top of the file, like:
SYMBOLSET
SYMBOL
END
This is a new requirement.
-Steve W
Ricardo Rodríguez wrote:
> hello all, a question, as I can uninstall and install mapserver an older
> version, since I is causing roughly following error and I think is the
> version of the same
> Warning: [MapServer Error]: msLoadSymbolSet(): First token must be
> SYMBOLSET, this doesn't look like a symbol file. in
> /var/www/obtra/vcauca.php on line 25
> Warning: Failed to open map file obtra_1.map in
> Fatal error: Call to a member function getLayerByName() on a non-object
> in /var/www/obtra/vcauca.php on line 33
> this in ubuntu 8.04 if it is not possible please where I can get an
> older version that I recommended to avoid mistakes and to update the
> system.
> thanks for your suggestions and answers
> Ricardo Rodríguez
> Univalle
> mapserver-users at lists.osgeo.org
