[mapserver-users] help(symbolset)
Ricardo Rodríguez
ricardorodot02 at gmail.com
Mon May 24 20:18:10 EDT 2010
hello all, a question, as I can uninstall and install mapserver an older
version, since I is causing roughly following error and I think is the
version of the same
Warning: [MapServer Error]: msLoadSymbolSet(): First token must be
SYMBOLSET, this doesn't look like a symbol file. in
/var/www/obtra/vcauca.php on line 25
Warning: Failed to open map file obtra_1.map in /var/www/obtra/vcauca.php on
line 25
Fatal error: Call to a member function getLayerByName() on a non-object in
/var/www/obtra/vcauca.php on line 33
this in ubuntu 8.04 if it is not possible please where I can get an older
version that I recommended to avoid mistakes and to update the system.
thanks for your suggestions and answers
Ricardo Rodríguez
Univalle
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100524/e674be37/attachment.html
