[mapserver-users] Re: Rendering Problem
Ibrahim Saricicek ibrahimsaricicek at gmail.com
Tue May 25 03:12:54 EDT 2010
- what are the data sources for these layers?
Postgis
- what are the library versions used for each MapServer build, are they
the exact same on both systems?
This is server side (local version is ms4w 5.4.0-rc2, not he same
libraries!!)
ii  libfreetype6                        2.3.7-2+lenny1           FreeType 2
font engine, shared library files
ii  libfreetype6-dev                    2.3.7-2+lenny1           FreeType 2
font engine, development files
ii  libgd2-xpm                          2.0.36~rc1~dfsg-3+lenny1 GD Graphics
Library version 2
ii  libgd2-xpm-dev                      2.0.36~rc1~dfsg-3+lenny1 GD Graphics
Library version 2 (development version)
ii  libgdal1-1.5.0                      1.5.2-3                  Geospatial
Data Abstraction Library
ii  libgdal1-dev                        1.5.2-3                  Geospatial
Data Abstraction Library - Development files
ii  libgdbm3                            1.8.3-3                  GNU dbm
database routines (runtime version)
ii  libogdi3.2                          3.2.0~beta1-3.1          Open
Geographic Datastore Interface Library -- library
ii  libpng12-0                          1.2.27-2+lenny2          PNG library
- runtime
ii  libpng12-dev                        1.2.27-2+lenny2          PNG library
- development
ii  optipng                             0.6.1.1-2                advanced
PNG (Portable Network Graphics) optimizer
ii  pngnq                               0.5-3                    tool for
optimizing PNG (Portable Network Graphics) images
- does that same problem occur if the layer is TYPE ANNOTATION ?
yes
- using ogrinfo to return the features through the commandline, does
GDAL/OGR return the same problem for that label layer?
don't know how to test
- what happens if you remove the 'WRAP' parameter?
nothing changes
- what happens if you use a different font type?
nothing changes. Tryed over 5 fonts including Monospaced Fonts.
Thanks in advance...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Rendering-Problem-tp5069072p5097222.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
