[mapserver-users] Re: msOracleSpatialLayerWhichShapes(): OracleSpatial error
Agostino acsviluppo at yahoo.it
Tue May 25 18:00:48 EDT 2010
Thank you Tamas.
I think that the new 5.6 functions does not work properly with oracle
spatial.
Also with the last build from http://vbkto.dyndns.org/sdk/ i have error.
The following code works:
layerObj lo = map.getLayer(i);
res = lo.queryByAttributes(map, null, strQuery.ToString(),
mapscript.MS_MULTIPLE);
resultCacheObj results = lo.getResults();
int numres = results.numresults;
for (int j = 0; j < numres; j++)
    int shapeInd = results.getResult(j).shapeindex;
    shapeObj shp = lo.getFeature(shapeInd, -1);
    layerObj loSel = GetSelectionLayer(map, lo.type);
    shp.draw(map, loSel, img);
but if i write this using new functions:
int numres = lo.getNumResults();
    resultCacheMemberObj reso = lo.getResult(j);
    shapeObj shp = new shapeObj((int)lo.type);
    lo.resultsGetShape(shp, reso.shapeindex, reso.tileindex);
i have the exception
msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error: ORA-00600:
codice di errore interno, argomenti: [17182], [0x2581CE802], [], [], [], [],
after call drawmap().
Agostino.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/msOracleSpatialLayerWhichShapes-OracleSpatial-error-tp5048929p5100718.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
