[mapserver-users] Re: msOracleSpatialLayerWhichShapes(): OracleSpatial
error
umn-ms at hydrotec.de
Wed May 26 07:22:23 EDT 2010
Hi
I'm facing similar/also strange problems.
I use
* mapserver 5.6.3,
* Linux-Redhat (Version ?)
* 64-Bit
* Oracle 11g on the DB-client
* Sun-Java 1.6
When creating some maps with a selection I get:
java.lang.UnknownError: msOracleSpatialLayerWhichShapes(): OracleSpatial
error. Error: ORA-00600: Interner Fehlercode, Argumente: [kokeaai5], [18],
[2], [], [], [], [], [], [], [], [], []
. Query statement: SELECT GEWAESSER_ID, NAME, GEWAESSER_ID,
DARSTELLUNGSSTUFE, shape FROM (select WWI.GEWAESSER.NAME,
WWI.GEWAESSER.SHAPE,
WWI.GEWAESSER.GEWAESSER_ID,WWI.GEWAESSER.DARSTELLUNGSSTUFE FROM
WWI.GEWAESSER) WHERE SDO_FILTER( shape, MDSYS.SDO_GEOMETRY(2003, :srid,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates ),'querytype=window')
= 'TRUE' . Check your data statement.
at edu.umn.gis.mapscript.mapscriptJNI.layerObj_queryByRect(Native
Method)
at edu.umn.gis.mapscript.layerObj.queryByRect(layerObj.java:513)
at
de.hydrotec.ims.umn.MapMetaInfoImpl.configureSelection(MapMetaInfoImpl.java:216)
* Problem occurs in most cases after making three selections
* Problem occurs on a 11g and a 10g databaseserver.
* What's *really* strange: A record in the queried table GEWAESSER is
corrupted!
Even though the mapserver-user has no UPDATE-GRANTS.
* No problems with mapserver 5.4.2. (This is my fallback for the current
project...)
Sorry for not being more specific.
But it's not easy to describe this strange behaviour. Never found
something like this.
I saw, that maporaclespatial in the SVN-trunk has some important fixes.
Question:
* Can I use the most current maporaclespatial from the trunk? Will it be
compatible with the rest of
mapserver5.6.3?
* Is there any hope, that this may help?
Benedikt
mapserver-users-bounces at lists.osgeo.org schrieb am 26.05.2010 00:00:48:
> Agostino <acsviluppo at yahoo.it>
> Gesendet von: mapserver-users-bounces at lists.osgeo.org
> 26.05.2010 00:01
> An
> mapserver-users at lists.osgeo.org
> Kopie
> Thema
error
> Thank you Tamas.
> I think that the new 5.6 functions does not work properly with oracle
> spatial.
> Also with the last build from http://vbkto.dyndns.org/sdk/ i have error.
> The following code works:
> layerObj lo = map.getLayer(i);
> res = lo.queryByAttributes(map, null, strQuery.ToString(),
> mapscript.MS_MULTIPLE);
> resultCacheObj results = lo.getResults();
> int numres = results.numresults;
> for (int j = 0; j < numres; j++)
> int shapeInd = results.getResult(j).shapeindex;
> shapeObj shp = lo.getFeature(shapeInd, -1);
> layerObj loSel = GetSelectionLayer(map, lo.type);
> shp.draw(map, loSel, img);
> but if i write this using new functions:
> int numres = lo.getNumResults();
> resultCacheMemberObj reso = lo.getResult(j);
> shapeObj shp = new shapeObj((int)lo.type);
> lo.resultsGetShape(shp, reso.shapeindex, reso.tileindex);
> i have the exception
> msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error:
ORA-00600:
> codice di errore interno, argomenti: [17182], [0x2581CE802], [], [], [],
> after call drawmap().
> Agostino.
> View this message in context: http://osgeo-org.
> 1803224.n2.nabble.com/msOracleSpatialLayerWhichShapes-OracleSpatial-
> error-tp5048929p5100718.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100526/446c88dd/attachment.html
