[mapserver-users] Filtering GetFeatureInfo requests
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Wed May 26 09:53:37 EDT 2010
Not possible using WMS GetFeatureInfo, the SLD parameter will be ignored,
it's not part of the GetFeatureInfo request at all.
Alternatively, you can create a WFS GetFeature request with the same
filter as in the SLD.
Best regards,
Bart
> Hi list,
> At the moment I am trying to figure out how to include a filter
> statement in a GetFeatureInfo request. I already tested this using a
> SLD-filter which works fine with a GetMap request. However, when
> combining this with a GetFeatureInfo request, I get all the features at
> that point. There is no filter being applied.
> I'm puzzled.
> First of all this is the SLD filter I am using:
> <?xml version="1.0" encoding="UTF-8"?>
> <StyledLayerDescriptor version="1.0.0">
> xmlns="http://www.opengis.net/sld"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/sld
> http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
> <NamedLayer>
> <Name>sdo_ldw_ccw_vlk</Name>
> <UserStyle>
> <Title>nvt</Title>
> <Abstract>nvt</Abstract>
> <FeatureTypeStyle>
> <Rule>
> <ogc:Filter>
> <ogc:PropertyIsLike wildcard='*' singleChar='.' escape='!'>
> <ogc:PropertyName>LOC_ZK</PropertyName>
> <ogc:Literal>*WERELD*</Literal>
> </ogc:PropertyIsLike>
> </ogc:Filter>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> </StyledLayerDescriptor>
> I use this GetMap request (works fine):
> http://<server>/cgi-bin/mapserv.exe?map=<path>\ldw_bsb_sdo.map&LAYERS=sd
> o_ldw_ccw_vlk&STYLES=&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:28992&BBOX=9
> 1000,435250,94000,438250&WIDTH=750&HEIGHT=750&FORMAT=image/png&TRANSPARE
> NT=FALSE&BGCOLOR=0xFFFFFF&SERVICE=WMS&SLD=http://<server>/db_vla_str.xml
> I use this GetFeatureInfo request (sadly doesn't work):
> o_ldw_ccw_vlk&STYLES=&VERSION=1.1.1&REQUEST=GetFeatureInfo&SRS=EPSG:2899
> 2&BBOX=91000,435250,94000,438250&WIDTH=750&HEIGHT=750&QUERY_LAYERS=sdo_l
> dw_ccw_vlk&X=325&Y=662&SERVICE=WMS&FEATURE_COUNT=25&INFO_FORMAT=applicat
> ion/vnd.ogc.gml&SLD=http://<server>/db_vla_str.xml
> I have tested this on Mapserver 5.2.1 and 5.6.3 without success.
> Has anyone got an idea how to solve this? Any help would be much
> appreciated! Thanks in advance.
> Geert
> mapserver-users at lists.osgeo.org
