[mapserver-users] Filtering GetFeatureInfo requests
Huizer, G.J. G.Huizer at gw.rotterdam.nl
Wed May 26 08:22:33 EDT 2010
Hi list,
At the moment I am trying to figure out how to include a filter
statement in a GetFeatureInfo request. I already tested this using a
SLD-filter which works fine with a GetMap request. However, when
combining this with a GetFeatureInfo request, I get all the features at
that point. There is no filter being applied.
I'm puzzled.
First of all this is the SLD filter I am using:
<StyledLayerDescriptor version="1.0.0">
  xmlns="http://www.opengis.net/sld"
  xmlns:ogc="http://www.opengis.net/ogc"
  xmlns:xlink="http://www.w3.org/1999/xlink"
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
  xsi:schemaLocation="http://www.opengis.net/sld
  http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
  <NamedLayer>
    <Name>sdo_ldw_ccw_vlk</Name>
    <UserStyle>
      <Title>nvt</Title>
      <Abstract>nvt</Abstract>
      <FeatureTypeStyle>
        <Rule>
          <ogc:Filter>
            <ogc:PropertyIsLike wildcard='*' singleChar='.' escape='!'>
              <ogc:PropertyName>LOC_ZK</PropertyName>
              <ogc:Literal>*WERELD*</Literal>
            </ogc:PropertyIsLike>
          </ogc:Filter>
        </Rule>
      </FeatureTypeStyle>
    </UserStyle>
  </NamedLayer>
</StyledLayerDescriptor>
I use this GetMap request (works fine):
http://<server>/cgi-bin/mapserv.exe?map=<path>\ldw_bsb_sdo.map&LAYERS=sd
o_ldw_ccw_vlk&STYLES=&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:28992&BBOX=9
1000,435250,94000,438250&WIDTH=750&HEIGHT=750&FORMAT=image/png&TRANSPARE
NT=FALSE&BGCOLOR=0xFFFFFF&SERVICE=WMS&SLD=http://<server>/db_vla_str.xml
I use this GetFeatureInfo request (sadly doesn't work):
o_ldw_ccw_vlk&STYLES=&VERSION=1.1.1&REQUEST=GetFeatureInfo&SRS=EPSG:2899
2&BBOX=91000,435250,94000,438250&WIDTH=750&HEIGHT=750&QUERY_LAYERS=sdo_l
dw_ccw_vlk&X=325&Y=662&SERVICE=WMS&FEATURE_COUNT=25&INFO_FORMAT=applicat
ion/vnd.ogc.gml&SLD=http://<server>/db_vla_str.xml
I have tested this on Mapserver 5.2.1 and 5.6.3 without success.
Has anyone got an idea how to solve this? Any help would be much
appreciated! Thanks in advance.
Geert
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100526/2411353b/attachment-0001.html
