[mapserver-users] Re: msOracleSpatialLayerWhichShapes():
OracleSpatial error
umn-ms at hydrotec.de
Thu May 27 02:59:36 EDT 2010
Some staring on maporaclespatial.c:
There are two global static variables in maporaclestapital:
static OCIType *ordinates_tdo = NULL;
static OCIArray *ordinates;
But as far as I understood mapserver-code should be threadsave.
In line 2011 ordinates is allocated with OCIObjectNew.
There's now corresponding OCIObjectFree.
Similar problem on allocation of ordinates_tdo?
Actually I don't think, that this solves my current problem...
Benedikt
Jim Klassen <klassen.js at gmail.com> schrieb am 26.05.2010 16:38:00:
> 26.05.2010 16:46
> An
> "umn-ms at hydrotec.de" <umn-ms at hydrotec.de>
> Kopie
> "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
> Thema
> Re: [mapserver-users] Re: msOracleSpatialLayerWhichShapes():
> OracleSpatial error
> One thing that I find particularly strange about these errors
> (ORA-0600) is that when you look them up they say "internal error -
> call Oracle". So while MapServer is probably doing something
> strange, the database is still failing in an unexpected way. I would
> expect it to return something from the OCI library or a more
> specific db error like invalid handle or invalid statement or
> something similar.
> Jim K
> On May 26, 2010, at 6:22 AM, umn-ms at hydrotec.de wrote:
> Hi
> I'm facing similar/also strange problems.
> I use
> * mapserver 5.6.3,
> * Linux-Redhat (Version ?)
> * 64-Bit
> * Oracle 11g on the DB-client
> * Sun-Java 1.6
> When creating some maps with a selection I get:
> java.lang.UnknownError: msOracleSpatialLayerWhichShapes():
> OracleSpatial error. Error: ORA-00600: Interner Fehlercode,
> Argumente: [kokeaai5], [18], [2], [], [], [], [], [], [], [], [], []
> . Query statement: SELECT GEWAESSER_ID, NAME, GEWAESSER_ID,
> DARSTELLUNGSSTUFE, shape FROM (select WWI.GEWAESSER.NAME,
> WWI.GEWAESSER.SHAPE,
> WWI.GEWAESSER.GEWAESSER_ID,WWI.GEWAESSER.DARSTELLUNGSSTUFE FROM
> WWI.GEWAESSER) WHERE SDO_FILTER( shape, MDSYS.SDO_GEOMETRY(2003,
> :srid, NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates
> ),'querytype=window') = 'TRUE' . Check your data statement.
> at edu.umn.gis.mapscript.mapscriptJNI.layerObj_queryByRect
> (Native Method)
> at edu.umn.gis.mapscript.layerObj.queryByRect(layerObj.java:513)
> at de.hydrotec.ims.umn.MapMetaInfoImpl.configureSelection
> (MapMetaInfoImpl.java:216)
> * Problem occurs in most cases after making three selections
> * Problem occurs on a 11g and a 10g databaseserver.
> * What's *really* strange: A record in the queried table GEWAESSER
> is corrupted!
> Even though the mapserver-user has no UPDATE-GRANTS.
> * No problems with mapserver 5.4.2. (This is my fallback for the
> current project...)
> Sorry for not being more specific.
> But it's not easy to describe this strange behaviour. Never found
> something like this.
> I saw, that maporaclespatial in the SVN-trunk has some important fixes.
> Question:
> * Can I use the most current maporaclespatial from the trunk? Will
> it be compatible with the rest of
> mapserver5.6.3?
> * Is there any hope, that this may help?
> Benedikt
> mapserver-users-bounces at lists.osgeo.org schrieb am 26.05.2010 00:00:48:
> > Agostino <acsviluppo at yahoo.it>
> > Gesendet von: mapserver-users-bounces at lists.osgeo.org
> > 26.05.2010 00:01
> > An
> > Kopie
> > Thema
> > [mapserver-users] Re: msOracleSpatialLayerWhichShapes(): OracleSpatial
error
> > Thank you Tamas.
> > I think that the new 5.6 functions does not work properly with oracle
> > spatial.
> > Also with the last build from http://vbkto.dyndns.org/sdk/ i have
error.
> > The following code works:
> > layerObj lo = map.getLayer(i);
> > res = lo.queryByAttributes(map, null, strQuery.ToString(),
> > mapscript.MS_MULTIPLE);
> > resultCacheObj results = lo.getResults();
> > int numres = results.numresults;
> > for (int j = 0; j < numres; j++)
> > int shapeInd = results.getResult(j).shapeindex;
> > shapeObj shp = lo.getFeature(shapeInd, -1);
> > layerObj loSel = GetSelectionLayer(map, lo.type);
> > shp.draw(map, loSel, img);
> > but if i write this using new functions:
> > int numres = lo.getNumResults();
> > resultCacheMemberObj reso = lo.getResult(j);
> > shapeObj shp = new shapeObj((int)lo.type);
> > lo.resultsGetShape(shp, reso.shapeindex, reso.tileindex);
> > i have the exception
> > msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error:
ORA-00600:
> > codice di errore interno, argomenti: [17182], [0x2581CE802], [],
> > after call drawmap().
> > Agostino.
> > View this message in context: http://osgeo-org.
> > 1803224.n2.nabble.com/msOracleSpatialLayerWhichShapes-OracleSpatial-
> > error-tp5048929p5100718.html
> > Sent from the Mapserver - User mailing list archive at Nabble.com.
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100527/6d09216f/attachment-0001.html
