[mapserver-users] MapServer as fast-cgi
Lars Lingner
ml at lingner.eu
Sun May 30 10:47:24 EDT 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 30.05.2010 16:10, Kai Behncke wrote:
> Dear users,
> I try to set up Mapserver with fast-cgi, but so far it doesn`t work as it should do
> (well I think it doesn`t, I`m also not so sure how to test ist).
> * I have succesfully compiled MapServer 5.6.3 with fast-cgi (on Debian 5.0)
> * Apache runs with mod_fcgid
> * In the mapfile I have implemented in the layers "PROCESSING "CLOSE_CONNECTION=DEFER"
> But some steps I don`t understand:
> In the apache-conf I set:
> ScriptAlias /fcgi-bin/ "/etc/apache2/cgi-bin/mapserv"
> <Location "/fcgi-bin">
> Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
> SetHandler fcgid-script
> Order allow,deny
> Allow from all
> #FastCgiConfig -initial-env PROJ_LIB=/usr/share/proj -initial-env #LD_LIBRARY_PATH=/usr/lib:/usr/local/lib:/usr/local/pgsql/lib #-appConnTimeout 60 -idle-timeout 60 -init-start-delay 1 -minProcesses 2 #-maxClassProcesses 30 -startDelay 5
> </Location>
> a) If I comment in FastCGIConfig ...... I always get from the Apache:
> "Invalid command 'FastCgiConfig', perhaps misspelled or defined by a module not included...." ??
> What might be the reason for that?
Does Apache load the fcgid module?
You can check in /etc/apache2/mods-enabled if its enabled
and in /etc/apache2/mods-available if its installed
Or check the error.log of apache:
[Sun May 30 16:38:27 2010] [info] mod_fcgid: server
/var/www/clients/client1/web1/fcgi-bin/mapserv(21099) started
I have the following config:
ScriptAlias /fcgi-bin/ "/path/to/fcgi-bin/"
Options None
Order allow,deny
Allow from all
</Location>
my /etc/apache2/mods-enabled/fcgid.conf looks like this:
<IfModule mod_fcgid.c>
AddHandler fcgid-script .fcgi
IPCConnectTimeout 20
</IfModule>
> b) I start the Apache without the "FastCGIConfig" in the apache-conf-file
> and I run the MapServer as:
> http://www.xyz.de/fcgi-bin/?map=/path_to_my/mapfile.map
> ...this should be the way to run MapServer as fast-cgi, shouldn`t it?
Hmm. I defined the scriptalias as path to the fcgi directory and not to
the binary. So the request URL is something like this:
http://example.org/fcgi-bin/mapserv?map...&...
But I don't know if your way might also be ok.
> c) I thought, if I run MS with "Debug 5" the layers should be produced much faster, right?
> But the log-file doesn`t show any difference betwenn MS as cgi or fcgi, this might be because of
> the missing FastCgiConfig in Apache, right?
With fcgi your MapServer processes will stay in memory. You should see
them within "top" even when the map is already delivered. And with
CLOSE_CONNECTION=DEFER you can then reuse database connections which in
turn will make your application faster.
Lars
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAkwCenEACgkQ0GRF77ebR/lSTACeO/vSeKLqQ1WphIb95/WqgZ3m
qOkAnjvmSo5NA1+6uE5b34RWOp7nZXPy
=lEMY
-----END PGP SIGNATURE-----
