[mapserver-users] mapfile
David Hildebrand
David.Hildebrand at afsc.ca
Tue Nov 2 14:16:56 EDT 2010
I have installed ms4w on XP and am trying to display a simple map with the following map file.
MAP
IMAGETYPE png
SIZE 600 400
EXTENT -120 49 -110 60
UNITS dd
SHAPEPATH "R:/GIS/"
LAYER
NAME "Elevation"
TYPE raster
DATA "srtm/elevation.tif"
END
END
I am testing mapserv from the command line with the following command
mapserv -nh "QUERY_STRING=map=R:/Program_Dev/DHildebrand/geoprocessing_server/MapServer/sample.map&mode=map"
The following output is returned, which, I presume, is a PNG stream but there are no errors generated.
ëPNG
IHDR ☻X ☺É☺♥ ☺?ⁿ╝M ♥PLTE º─←╚ 5IDATx£φ┴ü ├á∙S_ß U☺
|♠y↑ ☺░→ä♀ IEND«B`é
When but when I redirect the output to a *.png file, though, I simply get a blank white image. Any clues?
Thanks.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <about:www.afsc.ca> <http://www.afsc.ca <http://www.afsc.ca/> >
This communication is intended for the use of the recipient to which it is addressed, and may contain confidential, personal and/or privileged information. Please contact Agriculture Financial Services Corporation immediately if you are not the intended recipient of this communication, and do not copy, distribute, or take action relying on it. Any communication received in error, or subsequent reply, should be deleted or destroyed. Please consider the environment before printing this email.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101102/9992ae0d/attachment.html
