[mapserver-users] paths in the mapfile
David Hildebrand David.Hildebrand at afsc.ca
Tue Nov 2 15:50:15 EDT 2010
I have a map file which produces valid output from the command line but
not as a URL.  The map file is located in the htdocs directory but the
data source paths in the map file reference a different drive
altogether.  I don't want to make that drive accessible to the world but
I want the web server to be able to find it.  What parameter would I
change in the Apache configuration file to accomplish that?
Thanks.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <about:www.afsc.ca>  <http://www.afsc.ca
<http://www.afsc.ca/> >
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101102/0a7c7cbe/attachment.html
