[mapserver-users] WMS 1.3.0 questions
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Wed Nov 10 09:32:50 EST 2010
Yves,
this is only true for the GetCapabilities operation. Not for operations
such as GetMap.
Best regards,
Bart
> Yves,
> About the version parameter value: it only says which version you want to,
> not
> the one the WMS serveur **should** use. If WMS server can't serve this
> version, it will try the higher it can if client version > server version
> or
> the lower it can if client version < server version. The client version is
> the
> version value in the url, asked by the client.
> Regards,
> Y.
> Le mercredi 10 novembre 2010 03:48:56, Jeff McKenna a écrit :
>> Hello Yves,
>> Some related thoughts:
>> - related ticket for configuring default WMS version:
>> http://trac.osgeo.org/mapserver/ticket/3444 ...please add yourself to
>> the CC list of that ticket and join in the discussions and testing and
>> feedback, thanks
>> - doc pointers:
>> http://www.mapserver.org/ogc/wms_server.html#wms-1-3-0-support
>> ...specifically see the 2 working 1.3.0 example requests there
>> -jeff
>> > Hi All,
>> > I tried to look for an answer to the question "what do I have to do to
>> > get MapServer to serve a 1.3.0 WMS by default" and I haven't found
>> yet.
>> > Is there anything to do in the mapfile per se or is it just by the
>> > virtue of having a version >= 5.4 ? I thought the latter but then I
>> > tried things like :
>> > http://toMapserv.cgi?...REQUEST=GetMap&VERSION=1.3.0&CRS=EPSG%3A42304&BBO
>> > X=-5175875.27581...&WIDTH=1605&HEIGHT=316
>> > and
>> > http://toMapserv.cgi?...REQUEST=GetMap&VERSION=1.1.1&CRS=EPSG%3A42304&BBO
>> > and wondered if I'm getting back the response from a 1.3.0 in the
>> first
>> > case and a 1.1.1 in the second case. Both images were the same, so I
>> > thought everything was fine until I tried an unexisting version number
>> > (e.g. 1.1.122) and still got back an image !
>> > The only error message that made me think MS was indeed looking at the
>> > version number is when I submitted VERSION=abc. then MS complained it
>> > wanted "x.y" or "x.y.z". So how can I tell I get a real WMS with my
>> > specified version number instead of what appears to be a default one ?
>> > Doc pointers appreciated.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Responsable Formation et Support
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel (France) : +33 4 79 26 57 98
> Tel (Suisse) : +41 21 619 1031
> Mob. : +33 6 18 75 42 21
> Fax : 04 79 70 15 81
> Mail : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
