[mapserver-users] WMS 1.3.0 questions
Yves Jacolin yves.jacolin at camptocamp.com
Wed Nov 10 10:01:39 EST 2010
Hum ok.
Thanks Bart !
Y.
Le mercredi 10 novembre 2010 15:32:50, Bart van den Eijnden (OSGIS) a écrit :
> Yves,
> this is only true for the GetCapabilities operation. Not for operations
> such as GetMap.
> Best regards,
> Bart
> > Yves,
> > About the version parameter value: it only says which version you want
> > to, not
> > the one the WMS serveur **should** use. If WMS server can't serve this
> > version, it will try the higher it can if client version > server version
> > or
> > the lower it can if client version < server version. The client version
> > is the
> > version value in the url, asked by the client.
> > Regards,
> > Y.
> > Le mercredi 10 novembre 2010 03:48:56, Jeff McKenna a écrit :
> >> Hello Yves,
> >> Some related thoughts:
> >> - related ticket for configuring default WMS version:
> >> http://trac.osgeo.org/mapserver/ticket/3444 ...please add yourself to
> >> the CC list of that ticket and join in the discussions and testing and
> >> feedback, thanks
> >> - doc pointers:
> >> http://www.mapserver.org/ogc/wms_server.html#wms-1-3-0-support
> >> ...specifically see the 2 working 1.3.0 example requests there
> >> -jeff
> >> > Hi All,
> >> > I tried to look for an answer to the question "what do I have to do to
> >> > get MapServer to serve a 1.3.0 WMS by default" and I haven't found
> >> yet.
> >> > Is there anything to do in the mapfile per se or is it just by the
> >> > virtue of having a version >= 5.4 ? I thought the latter but then I
> >> > tried things like :
> >> > http://toMapserv.cgi?...REQUEST=GetMap&VERSION=1.3.0&CRS=EPSG%3A42304&
> >> > BBO X=-5175875.27581...&WIDTH=1605&HEIGHT=316
> >> > and
> >> > http://toMapserv.cgi?...REQUEST=GetMap&VERSION=1.1.1&CRS=EPSG%3A42304&
> >> > and wondered if I'm getting back the response from a 1.3.0 in the
> >> first
> >> > case and a 1.1.1 in the second case. Both images were the same, so I
> >> > thought everything was fine until I tried an unexisting version number
> >> > (e.g. 1.1.122) and still got back an image !
> >> > The only error message that made me think MS was indeed looking at the
> >> > version number is when I submitted VERSION=abc. then MS complained it
> >> > wanted "x.y" or "x.y.z". So how can I tell I get a real WMS with my
> >> > specified version number instead of what appears to be a default one ?
> >> > Doc pointers appreciated.
> >> _______________________________________________
> >> mapserver-users mailing list
> >> mapserver-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > Responsable Formation et Support
> > Camptocamp France SAS
> > Savoie Technolac, BP 352
> > 73377 Le Bourget du Lac, Cedex
> > Tel (France) : +33 4 79 26 57 98
> > Tel (Suisse) : +41 21 619 1031
> > Mob. : +33 6 18 75 42 21
> > Fax : 04 79 70 15 81
> > Mail : yves.jacolin at camptocamp.com
> > http://www.camptocamp.com
