[mapserver-users] WMS identify within ArcGIS
Bonnie James Bonnie.James at landgate.wa.gov.au
Thu Nov 11 00:46:16 EST 2010
Hi Mark,
A few years ago we did have a problem getting GetFeatureInfo queries to work with ArcGIS.
Have you had a look through your server logs to analyse the request that ArcGIS is sending?
In our case, ArcMap would send a request with the QUERY_LAYERS parameter present and correct, but the LAYERS parameters would be missing from the request. We use an ASP wrapper script for our services so we were able to add some code to parse the request, grab the list of layers from QUERY_LAYERS value, and use this to append the correct LAYERS parameter onto the request.
Hope that helps - feel free to email me if you want some more information on the wrapper script.
Cheers,
Bonnie
__________________________________
Bonnie James
Research Officer
Satellite Remote Sensing Services
Operations
Landgate
65 Brockway Road, FLOREAT WA 6014
Ph. (08) 9387 0342 | Fx. (08) 9383 7142
bonnie.james at landgate.wa.gov.au
www.landgate.wa.gov.au <http://www.landgate.wa.gov.au/>
From: mapserver-users-bounces at lists.osgeo.org on behalf of Mark Volz
Sent: Thu 11/11/2010 5:57 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] WMS identify within ArcGIS
Hello,
I am trying to set up Mapserver as a WMS server.  Currently I can draw maps.  However, I am having trouble getting the server to support Identify, specifically within ArcGIS.
Does anyone have an example map file and template that allows WMS Identify in ArcGIS.
Thank You
Mark Volz
GIS Specialist
Lyon County, MN
This e-mail and any files transmitted with it are intended only for the use of the addressee(s). It may contain information that is confidential and privileged, in which case neither is intended to be waived or lost by mistaken delivery to you. If you are not an intended recipient, any use, interference with, disclosure, distribution or copying of this material is unauthorised and prohibited. If you receive this e-mail in error, please notify the sender by return e-mail and delete the message and any attachments from your system. Unless specifically indicated, this e-mail does not constitute formal advice or commitment by the sender or the Western Australian Land Information Authority (Landgate). Information in this message not relating to the official business of Landgate shall be understood as neither given nor endorsed by it. It is your responsibility to check any attachments for viruses and defects before opening or sending them on. Landgate’s liability is limited to re-supplying affected attachments.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101111/1974c291/attachment-0001.html
