[mapserver-users] Another newbie needing help with a mapfile (projections)...
MM radar at netpalantir.it
Thu Nov 11 08:13:00 EST 2010
Hello!
I have a problem with Mapserver which I am apparently unable to solve. I
have a mapserver installation which is queried by a web component, that
uses virtual earth tile addressing. It works really great. My web
component queries it like this:
http://localhost/MapServ/mapserv.exe?map=mymap.map&mode=tile&tilemode=ve&tile=1202213133323032212&layers=aaa
Until now it worked with ECW files only, and I had no problems. But now
I need to add a shape file, and I just can't get it to work! I googled
extensively the whole morning but I was unable to find any solution.
Ogrinfo says this:
INFO: Open of ... using driver `ESRI Shapefile' successful.
Layer name: mattarello
Geometry: Polygon
Feature Count: 8270
Extent: (662941.920131, 5093593.286658) - (667764.802144, 5099438.607073)
Layer SRS WKT:
PROJCS["UTM Zone 32, Northern Hemisphere",
     GEOGCS["GRS 1980(IUGG, 1980)",
         DATUM["unknown",
             SPHEROID["GRS80",6378137,298.257222101]],
         PRIMEM["Greenwich",0],
         UNIT["Degree",0.017453292519943295]],
     PROJECTION["Transverse_Mercator"],
     PARAMETER["latitude_of_origin",0],
     PARAMETER["central_meridian",9],
     PARAMETER["scale_factor",0.9996],
     PARAMETER["false_easting",500000],
     PARAMETER["false_northing",0],
     UNIT["Meter",1]]
ogc_fid: Integer (10.0)
This map has the same extent as the ecw I am using and it was provided
by the same person, so I just thought to use the same projection as the
ECW. I also thought that the output projection should be the same as the
one I am using with the ECW, to work with the web component.
Unfortunately, all tiles I get are just blank, and calling mapserver in
map mode also renders a blank map.
If I comment out the projection inside the layer, calling mapserver in
map mode, it displays the map. But the tile is still blank.
I am probably using the wrong projection, but I really can't figure out
how to find the correct one, or how to translate the ogrinfo information
to the mapfile!
Here is the mapfile I am using.
MAP
   IMAGETYPE      PNG
   EXTENT         662941.920131 5093593.286658 667764.802144 5099438.607073
   SIZE           400 400
   SHAPEPATH      "."
   IMAGECOLOR 255 255 255
   CONFIG "MS_ERRORFILE" "mapserverlog.txt"
   CONFIG "PROJ_DEBUG" "ON"
   DEBUG 5
   OUTPUTFORMAT
     NAME png
     DRIVER "GD/PNG"
     MIMETYPE "image/png"
     IMAGEMODE RGB
     EXTENSION "png"
   END
   LAYER
     NAME aaa
     TYPE POLYGON
     DATA mattarello.shp
     STATUS DEFAULT
     CLASS
       NAME aaa
       OUTLINECOLOR 255 0 0
     END
     PROJECTION
       "proj=utm"
       "zone=32"
       "ellps=GRS80"
       "units=m"
       "no_defs"
     END
   END
   PROJECTION
	"proj=merc"
	"a=6378137"
	"b=6378137"
	"lat_ts=0.0"
	"lon_0=0.0"
	"x_0=0.0"
	"y_0=0"
	"k=1.0"
	"units=m"
	"nadgrids=@null"
	"wktext"
	"no_defs"
   END
END
Is there a way to display this shape on the tile?
Thanks for any help!!!
Palantir
