[mapserver-users] Mapscript vs fastcgi
Stephen Woodbridge woodbri at swoodbridge.com
Mon Nov 15 20:12:43 EST 2010
On 11/15/2010 7:51 PM, Ian Walberg wrote:
> We are testing an application which currently uses curl to call lighttpd
> (with fastcgi) and simple map files.
> When we do the same via the command line using the same map files but
> mapscript to render the image the difference is speed is huge, 4-5 time
> longer using php/mapscript.
>  From a first look the Drawing Label Cache is one of the main areas
> which is taking much longer, say 40-50 seconds instead of 2-4 seconds!
> Just about to start looking in more detail but hoping someone out there
> knows why the huge difference.
One of the first things I would check is make sure you are drawing both
images at the same scale. And that you are rendering the same layers.
Inclusion of an additional layer or a small scale change could
potentially throw a lot more objects into the label cache.
-Steve W
