[mapserver-users] opacity
Olivier Bedel o.bedel at alkante.com
Tue Nov 16 13:18:01 EST 2010
Hi Clément,
To change layers opacity in cgi call, something like that should work :
http://yourServer/cgi-bin/mapserv?map=yourMapfile&map.layer[yourLayerName1]=OPACITY%20yourOpacityValue1&map.layer[yourLayerName2]=OPACITY%20yourOpacityValue2
I don't know if it is possible at the map level...
Regards,
Olivier.
Le 16/11/2010 18:54, Clément MONIER a écrit :
> Hi,
> Is it possible to set layer's opacity dynamically ? with runtime
> substitution ?
> is there a way to set opacity for all layers of a mapfile ?
> Thank you for your help
> Clem
> mapserver-users at lists.osgeo.org
Olivier BEDEL
ALKANTE SAS
Ingénieur R&D SIG
1, rue du Chêne Morand
35 510 Cesson-Sévigné
Bur: + 33 (0) 2 99 22 25 70
fax : + 33 (0) 2 99 32 12 76
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101116/a2ea3f13/attachment.html
