[mapserver-users] problems generating image
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Nov 30 09:31:12 EST 2010
Hello,
Can GDAL read your sombras.tif file?  (what does 'gdalinfo sombras.tif'
return?)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 10-11-30 9:03 AM, Fco. Javier García Ricca wrote:
> *Hello,
> I'll tried to run my application with apache+php+mapserver+pmapper in
> RHEL. I'm getting the next errors when I run my application.*
> [Tue Nov 30 11:29:01 2010] [error] [client 10.226.103.16] PHP Warning:
> [MapServer Error]: msDrawMap(): Failed to draw layer named 'sombras'.\n
> in
> /var/www/html/cultura/museos/CAC/sicac/pmapper-4.0.0/incphp/map/map.php
> on line 326, referer:
> http://localhost/cultura/museos/CAC/sicac/necropolis_map.phtml?config=necropolis
> [MapServer Error]: msDrawRaster(): Unrecognized or unsupported image
> format\n in
> [MapServer Error]: drawEPP():
> /var/www/html/cultura/museos/CAC/sicac/datos_necropolis/sombras.tif is
> not an EPPL file.\n in
> [Tue Nov 30 11:29:01 2010] [error] [client 10.226.103.16] PHP Fatal
> error:  Call to a member function saveImage() on a non-object in
> /var/www/html/cultura/museos/CAC/sicac/pmapper-4.0.0/incphp/common.php
> on line 257, referer:
> *I check this:*
> *./mapserv -v
> MapServer version 5.6.4 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> **gdalinfo --formats
> Supported Formats:
>    VRT (rw+): Virtual Raster
>    GTiff (rw+): GeoTIFF
> *Everything seems ok and then I tried with:
> *./shp2img -m
> /var/www/html/cultura/museos/CAC/sicac/pmapper-4.0.0/config/necropolis/necropolis.map
> -o /var/www/html/cultura/museos/CAC/sicac/ms_tmp/prueba.jpg
> msDrawMap(): Image handling error. Failed to draw layer named 'sombras'.
> <br>
> msDrawRaster(): Image handling error. Unrecognized or unsupported image
> format <br>
> drawEPP(): Image handling error.
> not an EPPL file. <br>
> *I don't know what else can I try. Any idea to solve this problem.
> Thanks in advance
