[mapserver-users] WMS Request for a single point?
thomas bonfort
thomas.bonfort at gmail.com
Fri Oct 8 12:03:41 EDT 2010
have a look at http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg05881.html
the syntax for cgi commands has changed since then, you'd have to use
something like
&map.layer[site]=feature+points+582248.23+4841497.11+end+end
or &map.layer[site].feature.points=582248.23+4841497.11
(I cant remember what syntax is correct)
regards,
thomas
On Fri, Oct 8, 2010 at 17:10, Robert Hicks <robhyx at gmail.com> wrote:
> Hello all! Ok, this is probably a long shot but, is there a way to
> request an image from Mapserver that is just a point? The idea is I
> have another larger (reference) map image and I want to place a push
> pin on top of it in a specified point. It has to be a WMS call so that
> I can take the image and merge it with the other larger map into one
> so that it can be put into a PDF. Any help would be appreciated.
> Thanks!
> web http://www.hyxspace.com
> aim hyx1138
> mapserver-users at lists.osgeo.org
