[mapserver-users] Arabic text rendering
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Oct 21 16:39:54 EDT 2010
On 10/21/2010 4:20 PM, Ian Walberg wrote:
> Steve,
> Many thanks for you help, we had an old version of fribidi and building
> 0.19.2 fixed the character join issue.
> We do appear to have a couple of labels with square boxes (invalid chat
> I assume) at the end but I need to check the source data as well.
This means the the font is missing that particular joining character. I
would be interested in knowing if there is a good font that the fribidi
team recommends if you contact them or if you find one that is complete.
I have clients, that have licensed fonts that are more complete, by
still had to go in add a few additional glyphs. I do not remember what
font they got or where they got it from.
-Steve W
> Regards
> Ian
> -----Original Message-----
> From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
> Sent: Thursday, October 21, 2010 9:51 AM
> To: Ian Walberg
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Arabic text rendering
> The key is to make sure you are using fribidi-0.19.2.tar.gz I do not use
> fgs, so I'm not sure what they are using. I have downloaded the source
> and compiled and in stalled it under /usr/local/. Make sure you do NOT
> have the system package for fribidi installed as that is the old one
> that does not support the joining.
> Did you copy the font file you used for ms4w to linux to make sure you
> are using the same file?
> -Steve W
> On 10/21/2010 11:04 AM, Ian Walberg wrote:
>> Steve,
>> Thanks for the reply.
>> We have a working setup on Window using ms4w and used the same map,
>> shape and fonts files on the Linux setup which is an fgs install but
>> this shows the characters broken.
>> Is anyone out using a working linux installation which correctly joins
>> Arabic characters?
>> Thanks
>> Ian
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen
>> Woodbridge
>> Sent: Thursday, October 21, 2010 6:20 AM
>> To: mapserver-users at lists.osgeo.org
>> Ian,
>> You have to get a truetype font that supports arabic and has all the
>> chaining glyphs in it. Microsoft has an arial font that is about 24MB
>> file size that is pretty good, not that I'm suggesting you violate
> their
>> EUA. There are also some commercial fonts that you can buy that do the
>> job pretty well.
>> You might ask for font suggestions on fribidi software list.
>> As far as installation, all you need to do for maperver is copy the
> font
>> to a directory that your webserver can access, can create fontlist.txt
>> that points to that font. Then you can referrence the file via the
> alias
>> you gave it in the fontlist.txt file. See the documentation for how to
>> do this.
>> -Steve W
>> On 10/20/2010 10:08 AM, Ian Walberg wrote:
>>> Does anyone have any experience with Arabic text on a Linux
>>> installation?
>>> Thanks
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ian
>>> Walberg
>>> Sent: Monday, October 18, 2010 2:10 PM
>>> Subject: [mapserver-users] Arabic text rendering
>>> On Linux we are Arabic words rendered as individual characters and on
>>> Windows the characters are joined correctly.
>>> Same map file, shapefile and font on each.
>>> We have tried both the mapserver and libs we have built from source
>> and
>>> the fgs binary install on Linux and both render individual
> characters.
>>> Can anyone point me to what lib or config I need to change?
>>> Thanks
>>> Ian
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
