[mapserver-users] Display performance
Chris Jackson
webturtles at gmail.com
Thu Sep 2 16:28:43 EDT 2010
Hi
20 secs is from turning the layer on in the interface. The data is a model
grid as polygons, the file size is about 40mb. I agree 20secs is too long -
I am a web developer in general and know users are fickle! The other layers
load v.quickly so happy in general with performance of smaller model grids.
The same layer in an old arcgis server app loads a few secs quicker (from
SDE rather than file) and we just accepted it was just 'one of those things'
and deadlines got in the way - mmm...
The app is living on a reasonable specced server living in a data centre and
the old web app has been serving the offshore renewables industry fine for a
couple of years or so, just have a need to move to an open source solution.
I was trying to get a feel whether moving to PostGIS rather than local file
will speed things up - I get the feeling it is marginal.
Maybe I am missing another processing trick (admittedly I have done minimal
work bar a spatial index).
Thanks for the swift response.
Chris
On 2 September 2010 21:07, P Kishor <punk.kish at gmail.com> wrote:
> On Thu, Sep 2, 2010 at 3:03 PM, Chris Jackson <webturtles at gmail.com>
> wrote:
> > Steve
> > That saves some work, but how long would you expect one that size to
> load?
> > I have just realised (admittedly not looked at the data for a couple of
> > years) that it is actually 170,000 records - takes about 20 secs to load
> > sound reasonable?
> What does "to load" mean? Is 20 seconds the time elapsed from when the
> user clicks on the browser to when the user sees the resulting image?
> You are ripping through 170K features and creating an image. 20
> seconds seems like a lot. How big and complicated are those features?
> How big is the shapefile, in physical size (MB, KB).
> What kind of computer are you using?
> What other processes are running?
> So many variables...
> in any case, if you have a web app, and you want your users to remain
> interested in it, you probably will want to bring down the time "to
> load" to sub-second, or, at the most a few seconds. You will also want
> to consider multiple users -- acceptable performance with one user
> might translate into horrendous performance with several concurrent
> users.
> > Chris
> > On 2 September 2010 20:50, Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
> > wrote:
> >> That’s not that big a dataset. Probably faster from a local shapefile.
> >> Steve
> >> From: mapserver-users-bounces at lists.osgeo.org
> >> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Chris
> Jackson
> >> Sent: Thursday, September 02, 2010 2:29 PM
> >> To: mapserver-users at lists.osgeo.org
> >> Subject: [mapserver-users] Display performance
> >> Hi
> >> I wondered if anyone knew if displaying a 50,000 polygon dataset would
> be
> >> significantly faster if called from a database rather than a spatially
> >> indexed shapefile, or is it a similar overhead for both.
> >> Thanks
> >> Chris
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Puneet Kishor http://www.punkish.org
> Carbon Model http://carbonmodel.org
> Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
> Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
> Nelson Institute, UW-Madison http://www.nelson.wisc.edu
> Assertions are politics; backing up assertions with evidence is science
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100902/a9d851bd/attachment.html
