[mapserver-users] Possible tile_map_edge_buffer issue
forums
forums at craniumjuice.com
Tue Aug 2 10:20:39 EDT 2011
bump
Has anyone else encountered this issue?
Thanks
On Thu, Jul 28, 2011 at 9:18 AM, Charlie Allgrove
<charlie.allgrove at connectionservices.com> wrote:
> Hi
> I have an issue when using tile_map_edge_buffer functionality with mode=tile
> on a Google map view which displays the whole world at zoom 0,1 or 2. It
> probably manifests itself at higher zoom levels, but will be less obvious
> (if at all) since I'm only rendering data over land.
> In my map file I have (amongst others)
> WEB
> METADATA
> "tile_map_edge_buffer" "32" # 32 pixel rendering buffer
> "http_max_age" "86400"
> END
> END
> My development code is not on a publicly available server at the moment, so
> I can't post a link but when I am looking at a Google map at zoom levels 0,1
> or 2, the tiles consistently cut off approx half-way across the USA (see
> attached screenshot).
> It seems that {tile=0 1 2} does not render with the buffering enabled, since
> the buffered area extends effectively to a negative tile reference {-1 1 2}
> which is illegal.
> Is there any way around this - is it possible only to enable the buffer for
> zooms >=3?
> Cheers
> Charlie
> Charlie Allgrove
> Senior Developer
> Connection Services :: Business Mobility for a Wireless World
> Connection Services Ltd is a company incorporated under the laws of England
> and Wales with company number 6520674 whose registered office is at Griffins
> Court, 24-32 London Road, Newbury, Berkshire, RG14 1JX. The information in
> this e-mail and any attachments is confidential and may be legally
> privileged. It is intended solely for the addressee or addressees. If you
> are not an intended recipient, please delete the message and any attachments
> and notify the sender of misdelivery: any use or disclosure of the contents
> of either is unauthorised and may be unlawful. All liability for viruses is
> excluded to the fullest extent permitted by law. Any views expressed in this
> message are those of the individual sender. In accordance with the
> provisions of its Terms of Business the Company does not accept instructions
> or the creation of contractual obligations by unconfirmed electronic
> transmission.
> mapserver-users at lists.osgeo.org
A computer without Windows is like chocolate cake without mustard.
