[mapserver-users] MapServer as WMS client - HTTPS CERTIFICATE problem.
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Wed Aug 3 00:55:05 EDT 2011
With Windows MS4W is setting the path to local certificate file with environment variable CURL_CA_BUNDLE and by default it is \ms4w\Apache\conf\ca-bundle\cacert.pem with the setenv.bat
Perhaps you can tell where your modified certificate bundle file is with a mapfile too, but I have not tried it.  I have just added new certificates into the default cacert.pem.
I am not sure if it it possible to make Mapserver to pass on the --insecure parameter for curl to tell it trust anything without checking the certificate at all.
Have you read already http://trac.osgeo.org/mapserver/ticket/3070?
-Jukka Rahkonen-
 Bob Basques wrote:
> All,
> I did some more research on this.  Forwarding on my own posting from the user list here to ask a question,
> Couldn't the server certificate be added to the request process via a MAPFILE > METADATA field for inclusion in the requests, in lieu of adding it to the CURL cert request, or am I thinking > about this backwards?
> thanks
> bobb
Ok, got the debugging to spit out the actual request for a service, with the following CERT error ::
[Tue Aug  2 16:21:59 2011].998742 CGI Request 1 on process 14407
[Tue Aug  2 16:22:00 2011].23599 msHTTPExecuteRequests(): HTTP request error. HTTP: request failed with curl error code 60 (SSL certificate problem, ve
rify that the CA cert is OK. Details:
error:14090086:SSL routines:func(144):reason(134)) for https://xxx.xx.xxxxxx.xx/ArcGIS/services/StPaul/ParcelPolyWMSF/MapServer/WMSServer?LAYERS=0&
[Tue Aug  2 16:22:00 2011].23974 msDrawWMSLayerLow(): WMS server error. WMS GetMap request failed for layer 'Parcel Polygons' (Status -60: SSL certific
ate problem, verify that the CA cert is OK. Details:
error:14090086:SSL routines:func(144):reason(134)).
[Tue Aug  2 16:22:00 2011].23989 msDrawMap(): Layer 1 (Parcel Polygons), 0.000s
[Tue Aug  2 16:22:00 2011].24013 msDrawMap(): Drawing Label Cache, 0.000s
[Tue Aug  2 16:22:00 2011].24026 msDrawMap() total time: 0.025s
[Tue Aug  2 16:22:00 2011].77595 msSaveImage() total time: 0.053s
[Tue Aug  2 16:22:00 2011].77691 mapserv request processing time (loadmap not incl.): 0.079s
[Tue Aug  2 16:22:00 2011].77701 msFreeMap(): freeing map at 0x7144b0.
Question, can this be handled in the MAPFILE somehow?  I did verify that the request works, once it's sent, by pasting into a Browser that already accepted the certificate.
